Toe-in help!
Old 08-06-2012, 07:04 PM
Trader Rating: 237 (100%+)
Default Toe-in help!
Is it possible to get the rear toe-in out back to around zero? New to these trucks.
Andy Koback is offline
Old 08-06-2012, 07:11 PM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Toe for the rear is adjusted by the block inserts or pills. The Rear Rear block adjusts your toe normally the standard is between 2.5-3.5 pending on kit.
Running no toe will make the car very unstable you will have a hard time tracking why 0 maybe your coming off on road with tons of traction?
bigjayjay1 is offline
Old 08-06-2012, 07:32 PM
SolderGlob's Avatar
Which kit are you talking about?
SolderGlob is offline
Old 08-07-2012, 06:11 PM
Kit #90004. Want to run this on carpet oval. Don't need the toe-in. New to this kind of truck.
Old 08-07-2012, 07:09 PM
SolderGlob's Avatar
For future reference, it might be wise to specify the EXACT kit you're asking for help with. I.E., Associated 90004 or SC10 4x4 for this particular question.
If my assumption on this being the SC10, then it uses an hingepin type setup so your two options of zero-toe are either rear hubs or rear arm mounts. It would seem that this truck uses the arm mounts to set rear toe.
I'm not that familiar with Associated products so I don't know what the numbers mean but STRC offers a 3-2 arm mount, a 3-3 arm mount as well as an unlisted arm mount for adjustability. There are probably other manufacturers that have more options to give you zero-toe.
Hope this helps.
Old 08-08-2012, 05:42 PM
Hope this helps.
Thanks! Will check this stuff out.
