    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-05-2017, 07:34 PM   #14491
oPAULo's Avatar
Went back to 4 gear and cut off the waterfall after seeing so many do it. Our local track is low/medium bite. Really enjoyed it.
oPAULo is offline   Reply With Quote
Old 11-06-2017, 05:26 AM   #14492
Trader Rating: 21 (100%+)
Finally got a chance to run the RTR 6.6 with my son this weekend. We run on a carpet track so the stock tires got changed to Schumacher mini pins and staggered cut after the first pack. For a person with smaller hands like my 12yr old son the included TX is no good. The throw on the trigger is to long so he had to struggle a bit to get used to it. Shock package was very squishy so I put a set of 2x1.6 Pistons and 45f/40r shock oil, red springs on front and it changed the car immediately to the better. After a few more packs we kept going into thermal shutdown after a few minutes. The smallest pinion I could fit was a 20t and that helped get our run times up to about 8min. Still gets way hot after a run. Had to fiddle with the battery mounts a bit to get a shorty mounted transversely.
Overall I'm happy with the RTR. It didn't take a whole lot of messing around to get it setup for the carpet. Have lots of room for improvement but the car really reacts to any adjustments made to it. I'm not used to that. Sometimes on my other cars I'll make an adjustment and I can't tell the difference but this thing gives allot of feedback to setup changes.
76jimmy is offline   Reply With Quote
Old 11-09-2017, 12:52 PM   #14493
Default Diff Rebuild
Does anyone make a diff rebuild kit or are we stuck buying the parts seperately?
AndyThomas is offline   Reply With Quote
Old 11-10-2017, 07:32 AM   #14494
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Not that I am aware of.
I usually purchase the following:
UM119 Diff Ring
BRG100 Diff.Thrust Bearing
UM120 3/32 Ball (14pcs)
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-10-2017, 11:06 AM   #14495
JAE
Trader Rating: 28 (100%+)
This will save you a ton of money
https://m.ebay.com/itm/NEW-KYOSHO-ULTIMA-RB6-6-Diff-Balls-BRG100-97030-RB6-RT6-KB13/131883063580?hash=item1eb4d7d91c:g:UdAAAOSwtnpXjsP 7
https://m.ebay.com/itm/NEW-KYOSHO-ULTIMA-RB6-6-Diff-Rings-Hardware-SC6-RT6-RB6-KB18/132366164224?hash=item1ed1a36100:g:croAAOSw~l1Z5WA V
JAE is offline   Reply With Quote
Old 11-10-2017, 06:07 PM   #14496
Send a message via Yahoo to nitro-rob Send a message via Skype™ to nitro-rob
B-fast makes great kits that are very high quality. I can't see their website now, but their kits are sold at various online retailers. I don't use the Kyosho-plates, go straight to these and eventually use the whole kit. Have for a few years now, they are super smooth and wear very well.
nitro-rob is offline   Reply With Quote
Old 11-10-2017, 06:13 PM   #14497
bfastrc.com, but the site is down now. Their facebook page is active, I am guessing the website/store is just temporarily down.
Old 11-10-2017, 06:49 PM   #14498
hairymuffin's Avatar
Trader Rating: 94 (100%+)
Do you guys sandbtge diff rings?
hairymuffin is offline   Reply With Quote
Old 11-11-2017, 08:04 AM   #14499
Super Moderator
Kraig's Avatar
I don't sand the Kyosho rings. I look at the edges and you will see one side is rounded and the other is flat. I put the rounded edges towards the diff gear.
Once I have it built, I break it in on the bench for 5-10 minutes to get everything seated.
Old 11-11-2017, 09:36 AM   #14500
Thanks kraig!
Old 11-14-2017, 01:11 PM   #14501
Payment recieved
Baha x is offline   Reply With Quote
Old 11-19-2017, 08:20 AM   #14502
watzonee's Avatar
Anyone know if you can put a lay down diff in a RB6? Or would that require a 6.6 chassis plate due to extra holes....
El Rey
Welding & Fabrication
watzonee is offline   Reply With Quote
Old 11-19-2017, 09:57 AM   #14503
The transmission gears are the same between 6 and 6.6. To convert to the laydown config, you need a new transmission case, motor plate, and a few other things listed on the first page of this thread. You do not need a new diff. If using the 6 chassis, you will need to drill 2 holes in the chassis.
heyscottn is offline   Reply With Quote
Old 11-19-2017, 06:42 PM   #14504
watzonee's Avatar
Thanks heyscottn that is what I wanted to hear... Thanks.....
El Rey
Old 11-28-2017, 08:38 AM   #14505
watzonee's Avatar
Hey guys on a RB6 can you mount the rear shocks in front of the tower?? Do you need a different rear bulkhead to get the angles right??
El Rey
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15037 Yesterday 08:18 PM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22989 12-10-2017 04:00 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
