Losi Bleeder Shock Caps?
I'm using the losi bleeder caps. Would you use the original bladders? Getting conflicting answers. The losi caps come with an o-ring.
if you use the bleeder shock caps it may be more beneficial to go with an emultion type set up for your shocks.
if you want to use bladders then you would not use the o ring that came with the bleeder caps.
it all depends on how you like your shocks working
Yep, most guys are running the O-rings as far as I've seen, at least on 22 stuff. No bladders. The bleeder caps are a lot easier to get a good consistent build with.
