savage flux help.
I am about to get a savage flux hp in a trade and the fluxs come stock with deans and all I use is trx connectors do they sale any deans to trx series connectors or anything like that so I don't have to solder
No, and i wouldn't use them on that high powered mamba monster. You want the most direct connections you can get. What i did before i learned to solder was cut the plastic casings off the deans connectors and push the blades into a traxxas male connector. They are pretty much the same size as what traxxas connectors use. The only problem is that the original connectors dont have the locking pins like the traxxas ones use. Just make sure you put some tape around the wires and connectors to keep them from slipping out. My advice if you dont do that, find somebody who reguarly solders traxxas connectors to wire it up for you.
Ok will prolly take it to my local hobby shop and get it soldered
I can solder traxxas connectors I do it all the time but I just don't wanna mess up a $150-200 esc
