XXX-SCB rear hubs >
XXX-SCB rear hubs
XXX-SCB rear hubs
Old 07-28-2012, 10:22 PM
ridepate's Avatar
Default XXX-SCB rear hubs
What degree are the stock rear hubs??? Don't want the stock plastic but the stock degree...Why you ask??? Upgraded the links and the shock-load went elsewhere....
ridepate is offline
Old 07-29-2012, 12:12 AM
RadioRogue's Avatar
I would recommend these: Team Losi Racing Aluminum Rear Hub Set
[TLR2140] http://c456141.r41.cf0.rackcdn.com/i...lr/tlr2140.jpg
You can move the rear outer pivot point out to the outer hole in the arm and it really helps with rear traction.
RadioRogue is offline
Old 07-29-2012, 12:03 PM
ridepate's Avatar
Thanks I'll try that. Appreciate the PN# also.
ridepate is offline
