Please help diagnose motor problem.
A friend was running his RTR SC10 today. Stock brushed motor running with 5000mah 40c 2s lipo. He's put less than 10 batteries through this motor. While running today, it seemed to be running OK until he hit some pipe and tried to backup, it had completely died. We tried multiple batteries, motor appeared dead.
He took it apart and blew it out with a air hose, every looked OK. He got it back together and it still isn't turning. Once we did some testing with a multimeter, a AA battery and a NiCD, here's what we were able to find:
- With the motor out of the truck, he touches the connectors to the appropriate ends of a AA battery. The motor turns.
- When he touches the connectors to the appropriate ends of the NiCD battery, the motor turns.
- With the motor disconnected from the ESC and using a multimeter to test the voltage coming out of the ESC, idle reads around 0.5v and up to full throttle reads almost 17v. Going from idle to full gives the appropriate voltage increase.
However, as soon as we connect the motor to the ESC, we get nothing. I get no voltage read from where they connect. These are the normal bullet connectors on RTR vehicles. It's like as soon as they are connected, the ESC decides it doesn't want to output anything. The lights on the ESC still light accordingly (i.e. green for throttle, red for brake, dim amber at idle).
Can anyone tell me what's going on with this?
what is the esc?
What would cause it to do this? Just seems weird it will output voltage and then once it sees the motor, says "hell no".
