best connectors to use >
Old 07-27-2012, 03:34 AM
Suspended
Trader Rating: 1 (56%+)
Default best connectors to use
What is the best battery connectors to use and does different battery connectors make a difference in how the battery performs I use trx high current connectors but thinking about switching to deans should I stay with traxxas or switch to deans
tyler144 is offline
Old 07-27-2012, 04:28 AM
RatsacK's Avatar
Trader Rating: 21 (100%+)
I'd stick with the TRX connectors. You won't gain any advantage switching to Deans unless you have friends/other racers that use Deans and you would share batteries with.
RatsacK is offline
Old 07-27-2012, 05:02 AM
Traxxas plugs actually handle more amperage than deans and have bigger contact surface, so going to deans would be a downgrade.
Arakon is offline
Old 07-27-2012, 06:50 AM
EC3 for small amps and EC5 for more
Bigbearfin is offline
Old 07-27-2012, 07:09 AM
M03Racer's Avatar
Trader Rating: 33 (100%+)
I used them all and the best is still Deans although the chinese market is pushing the banana connectors racers still use Deans. Here is why easy to connect it stays connected and its easy to disconnect that is why Deans are still the most popular amongst racers, now if you just bash then anything will do. Contrary to what some say in this thread it is not a down grade it allows just as much amps to flow to your ESC. Please check your facts before you post false data Arakon. My advice is if you have TRX and just bash then stick with them. If you wanna race or plan on racing then deans are much easier to work with believe me when you wanna disconnect your battery without removing your RC's body deans are a lot easier to disconnect then TRX.
M03Racer is offline
Old 07-27-2012, 12:35 PM
Trader Rating: 21 (96%+)
deans
john stu is offline
Old 07-27-2012, 01:00 PM
Marcthequad's Avatar
Trader Rating: 49 (100%+)
No choice......Deans.
Marcthequad is offline
Old 07-27-2012, 01:58 PM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You want to know the BEST plug? There is only one answer:
https://www.speedtechrc.com/store/eb...id=64&id=12269
Cpt.America is offline
Old 07-27-2012, 02:30 PM
So*Cal AFDude's Avatar
So*Cal AFDude is offline
Old 07-27-2012, 03:11 PM
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
If you want to use a connector and not a 4mm bullet. Deans and NOT Chinese knock offs. Get actual Deans. They are not the same. All of the spring load or push and lock connecters tend to back off and make your connection crap. Dean do require a little bit better soldering skill though
Wildcat1971 is offline
Old 07-27-2012, 03:18 PM
BlueGlowBoy's Avatar
I found Deans easier to put together than TRX connectors.....
But yes, definatley stick with genuine Deans. The knock-offs often don't fit together well. I have a Deans (knock-off) to servo style plug adapter to charge the RX pack in my nitro buggy, and it is SOOO tight, I'm worried about tearing the wire any time I need to remove it. Any of my genuine deans to deans connections are super smooth, and I've NEVER had one pull apart unless I want it to.
BlueGlowBoy is offline
Old 07-27-2012, 03:21 PM
yeah, I bought a pack for my kids car with a knock deans connector. I put a real deans on her esc, but she cant even plug or unplug it. I also fear I might rip the wires out. Real dean plug together well and stay pluged.
Old 07-27-2012, 03:42 PM
Since this subject comes up so often, I'll throw my choice in, just to muddy the waters a bit more.
Anderson Power Poles and Powerwerx's crimper.
Jeckler is offline
Old 07-27-2012, 03:48 PM
nismomike's Avatar
I found a really great article online a while back about this topic and lipo's in general. I thought it was a good informative read and seemed helpful. Whether or not somebody agrees with the connectors amp rating is debatable. I do know that the heli guys know their stuff though. They discuss connectors about 2/3 down the page.
http://www.rchelicopterfun.com/rc-lipo-batteries.html
I personally have switched everthing over to bullets from trx connectors.
nismomike is offline
Old 07-27-2012, 04:12 PM
Not directed at you, just a tip prompted by your last comment. Have the Dean’s plugged together while soldering, helps with heat dissipation and preventing/reducing distortion that can make them unnecessarily difficult to pull apart. Doesn’t mean working on those soldering skills isn’t needed, important skill in this hobby regardless, for those who need it check out the excellent sticky thread in the Radio & Electronics forum.
And yes, I remember the FX10. Well sorta….
Dave H is offline
