Team C TC02/TC02 EVO thread
#1246
I just assembled my tc02 kit and tested it. The screw and locknut which holds the ball diff together keep coming loose. I changed the locknut but it didn't helped. I could have stripped the screw but don't have a spare 2.5mm 25mm long screw . Is this a known issue for ball diff ?
I want to use ball diff but if it has issues I might consider to get a gear diff.
#1247
#1248
On which side should be the screw ? left or right outdrive?
#1251
http://www.rctech.net/forum/r-c-item...l#post11839776
#1252
#1253
I also know guys who use it with no problems at all.
One quick and permanent fix is to switch to this: http://www.amainhobbies.com/product_...Diff-Screw-Set
No mods needed and the hardware is much stronger, plus you ditch the phillips head. I haven't had a single problem since switching to this hardware.
#1257
I've had issues with that nut/screw stripping.
I realized I've stripped the screw. I changed it and problem solved
#1258
I did it like the manual says.
Funny thing is, at the track some people are pretty confident that is wrong.
Mine is not loosening so I guess stick with the manual.
The manual could be more clear about this.
#1259
I used the TU0238 Ceramic balls inside my diff.
I had to make the diff very tight for it to not "bark".
Sometimes I still hear it bark on a carpet track. (high grip)
The slipper is as loose as possible.
Any way to improve this?
When is the diff too tight?
If the plastic nut holder goes bananas?
Thx!
Thx!
