Team C TC02/TC02 EVO thread
#2102
We also run the hard springs
And about 40/45 wt oil.
#2105
^ what he said
hard springs and play with shock oils in that range. i would try 45wt front/40wt rear. try different shock positions.
#2107
I have the same gripe, I hate e-clips. You're right that it WAS the standard. As in they're now out-dated.
I went out and found e-clips in bulk since I break them every time I try to remove one and half the time I try to install them. I got 250 (of whatever size the ones for the hinge pins are) for around $11 on eBay.
#2109
No issiues here with them also
But for looks i prefer like tm4 with a setscrew in the hubs..
#2111
Modern servo's are super strong now, that's why you see so many fixed aluminum steering assemblies now.
Front oil too light for sure and yea go up in springs. When I ran on carpet with my T2 Evo I was TLR 40 with black piston and TLR Green spring out on arm and middle on tower. Rear was TLR 30 white piston TLR Pink spring in on arm and middle on tower.
I used a shorty pack all the way forward, gear diff with TLR 2000 ESC behind the shorty down on the chassis.
#2112
Not on that part, there are no threads,
There is going to be some tolerance on both the balls and the holder they go in, that being said I think you will be fine to run them, if there is a lot of slop the holder those go in might be worn out along with the balls,
On my buggy most of the slop is actually front to back but it seems like it's in the balls, check that you can't wiggle the arms front to back and if so try shimming that out, if there is play it doesn't seat those balls all the way into their pockets
