Team C TC02/TC02 EVO thread >
Old 03-17-2014, 04:59 PM
  #2086
Trader Rating: 28 (100%+)
Originally Posted by darkdays View Post
Can anyone tell me what's the spring rate for the stock Team C big bore shocks?
I just upgraded on my Evo and feel that the spring is abit too stiff at where I'm driving. A friend of mine told me that the stock spring is medium and I should buy a soft spring rate. How true is this?
Are big bore springs universal? What other brands of springs are compatible with it?
If you read back some pages in either this thread or the team c USA one there is a nice PDF comparison chart for spring rates,
bobf24 is offline
Old 03-18-2014, 08:00 AM
  #2087
IntegraMark's Avatar
I guess mine would be the same, medium traction clay. Will try your setup once I get my hands on the Losi springs.
Thanks alot!!
Oh Mark, since we are on the same track condition, care to share your setup? Are you running gear diffs? If so, what oil visc? How abt your shock oil visc as well?
I run gear diff w/5000wt.
I'll try and post a complete setup sheet when I get home. I'm happy with it, it's very sensitive to steering and throttle input.
IntegraMark is offline
Old 03-24-2014, 05:51 AM
  #2088
Hi guys,
I am looking to upgrade my front C type holder hubs and was referred to TU0219 and TU0220. My question is, what is the 25 degrees and 30 degrees apply to? How will it affect the handing of the buggy?
darkdays is offline
Old 03-24-2014, 05:55 AM
  #2089
How do you make the gear diff to stop leaking?
I've changed the paper gasket and the cups o-ring.
I've tried green slime on the o-rings, as well as AW grease on the cup shafts.
No matter what I do, my diff always end leaking all the oil.
Any advice?
prorace is offline
Old 03-24-2014, 02:30 PM
  #2090
Hi guys,
it applies to the caster angle
this should explain it for you.
http://www.competitionx.com/rc-racin...tuning-caster/
Any advice?
green slime works for me. try applying some to the gasket as well
Old 03-24-2014, 02:36 PM
  #2091
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Any advice?
Flat sand the gear case with 200grit sandpaper, make sure you do it on a flat surface. Afterwards lightly coat the paper gasket with silicone sealant on both sides(preferable one that does not harden). It will never leak again
MantisWorx is offline
Old 03-28-2014, 06:10 PM
  #2092
Hi guys i am new to 2wd 1/10 buggy class and i started with Team-C. I have some steering issue by the way. I can t solve that. I try almost everything but the result is same. We are racing on carpet and i have proline pinpoint on back and wedge on front. Also i have 30 g brass arm mount on front.
pagwon is offline
Old 03-29-2014, 10:26 PM
  #2093
Which model car are you using? what exactly is the issue you're having? I need more details before I can suggest anything.
Old 03-29-2014, 10:32 PM
  #2094
MantisWorx's Avatar
If you are running anything other than the TM2 or TCo2C on carpet you are going to have bad on power steering, its the nature of RM cars.
Old 04-01-2014, 02:38 AM
  #2095
I am running T2 Evo. Steering is too weak even on power and off power. I think something wrong.
pagwon is offline
Old 04-01-2014, 02:44 AM
  #2096
I know mm is better but the fastest guy also using rm buggy (serpent) . And when i try his car my lap time reduce around 2 sec (fastest lap 13.45 with his car 14.88 with mine )
pagwon is offline
Old 04-01-2014, 07:14 AM
  #2097
what springs and oils are you running? what tires? how tight is your servo saver? what servo?
with all my carpet vehicles, I run my servo saver as tight as it'll go.
Old 04-01-2014, 04:05 PM
  #2098
Check you steering travel too, I would guess your servo saver is too loose or end points are the issue
bobf24 is offline
Old 04-01-2014, 04:55 PM
  #2099
marcel p's Avatar
Make it heavy at the front. About 60 grams .
Gear diff oil 800/1000
I run a tm2v2. At carpet
But a local guy runs a t2evo and his car runs great.
I tryed it and run almost te same laptimes with his evo as i do with my v2
marcel p is offline
Old 04-02-2014, 12:01 PM
  #2100
Stock sprigs and 27.5 - 30 oil f/b proline pinpoint and wedge combo. Savöx 1258 servo. I didn't check the servo saver. Maybe it is the problem...
pagwon is offline
