Team C TC02/TC02 EVO thread >
Old 03-04-2014, 08:55 PM
  #2071
mjbtaco's Avatar
Barnyard up in Canada? Hook up with Darrin Quinn he has dialed setups for that track. I'll ask him to help you out.
mjbtaco is offline
Old 03-05-2014, 05:46 AM
  #2072
I know darin but i havn't seen him latley.
hockeyrules16 is offline
Old 03-06-2014, 12:04 PM
  #2073
savageboy69's Avatar
Trader Rating: 93 (100%+)
Originally Posted by hockeyrules16 View Post
hi guys i have a setup question
i am really happy with the steering but it doesn't feel stable/planted and i don't feel like i can push the car.
thx in advance for any advice
Its usually easier to fill out a setup sheet and post it, good way to keep track of your setup for different tracks, and makes it easier to get help on what may need to ve changed
savageboy69 is offline
Old 03-09-2014, 12:37 AM
  #2074
snaketaco's Avatar
It was recommended a while back to use a gear diff with black grease. Is this still the way to go. I will be running on low bite outdoor. Thanks
snaketaco is offline
Old 03-09-2014, 06:29 AM
  #2075
MantisWorx's Avatar
Trader Rating: 28 (97%+)
I like 2k but lately i have been running 20k on my TM2 on loose dirt and its really good. Going to try on the EVO soon. Go with 2k and you will like it.
MantisWorx is offline
Old 03-09-2014, 12:14 PM
  #2076
IntegraMark's Avatar
for a lower bite outdoor track I use 7k in my evo.
IntegraMark is offline
Old 03-10-2014, 11:48 AM
  #2077
nissan240's Avatar
Trader Rating: 8 (90%+)
Great deal many option parts!
http://www.rctech.net/forum/r-c-item...l#post13082005
nissan240 is offline
Old 03-10-2014, 12:11 PM
  #2078
snaketaco's Avatar
Thank you guys.
Old 03-14-2014, 10:17 PM
  #2079
snaketaco's Avatar
Would the 4wd rear arm mod be a good idea for low bite outdoor? Thanks
Old 03-14-2014, 10:18 PM
  #2080
DustinH's Avatar
Trader Rating: 26 (100%+)
I'm going to find out since mine has them. Seems good so far.
DustinH is offline
Old 03-15-2014, 01:50 AM
  #2081
Can anyone tell me what's the spring rate for the stock Team C big bore shocks?
I just upgraded on my Evo and feel that the spring is abit too stiff at where I'm driving. A friend of mine told me that the stock spring is medium and I should buy a soft spring rate. How true is this?
Are big bore springs universal? What other brands of springs are compatible with it?
darkdays is offline
Old 03-15-2014, 06:01 AM
  #2082
DustinH's Avatar
You can use TLR springs.
DustinH is offline
Old 03-15-2014, 08:28 PM
  #2083
front - 3.4
rear - 2.1
what kind of surface are you running on? I run on a medium traction clay with mine and currently have Losi reds up front and whites in the rear.
Old 03-16-2014, 09:58 AM
  #2084
Originally Posted by IntegraMark View Post
front - 3.4
rear - 2.1
I guess mine would be the same, medium traction clay. Will try your setup once I get my hands on the Losi springs.
Thanks alot!!
Oh Mark, since we are on the same track condition, care to share your setup? Are you running gear diffs? If so, what oil visc? How abt your shock oil visc as well?
darkdays is offline
Old 03-17-2014, 11:30 AM
  #2085
Woulvesbaine's Avatar
Thanks alot!!
I am running low-med traction clay (not really sure if one man's medium is another man's low) and I'm currently trying the gear dif with 1000 wt, which feels about right.
I feel the ball diff turns a tiny bit more, but when I brake with the gear-diff I can very predictably hook the rear around. Both are very good. I may switch back to the ball diff just to compare with my most recent setup.
I am running MJBTaco's setup, which is essentially:
Front shocks:
Team C light spring
AE 30 wt oil, AE 1.6x2 pistons
Inside hole tower, outside hole arm
Rear shocks:
Team C medium (kit) spring
AE 27.5 wt oil, AE 1.6x2 pistons
Middle hole tower, outside hole arm
Rear hub outer most hole camber link.
Rear tower upper inside camber link.
Someone should have a .pdf of this somewhere, but you can try that. MJBTaco also runs aluminum shock base rear and weighted brass front arm mount.
Woulvesbaine is offline
