Team C TC02/TC02 EVO thread
#1951
Has anyone tried the JConcepts Illuzion body for the Kyosho RB5 on their TC02?
#1954
Its not so much the offset but if you look at the hole the axle goes through. The plastic is actually thicker. With the proline rim fitting the b4/rb5/22 the offsets should be reasonably similar. When I use the prolines or the 22 rims on mine I use a team Durango serrated nut that is a low profile nut that doesn't use nylon in it. they come in like a ten pack for a couple bucks .
#1957
Which platform (b4.2, 22 2.0, etc) bodies fit the the TC02 Evo?
#1958
I'm picking up a TC02 Evo buggy this next week and I had a couple questions.. Does the buggy use metric or hex hardware? What sizes should I pick up?
Also, does anyone have a picture of the RB5 body on their Team C buggy from the underside so I can see how well it fits?
#1961
Phillips screw in the diff? I wonder how that happened… I'll have to look up a replacement screw for that one then Haven't used phillips screws on an RC car since I was 13 and bought a Traxxas Rustler
Now if only someone had an RB5 body they could take a pic of
Hmmm found the screw in the manual.. Looks like 2.5 x 25 size..
#1964
Well that makes things a whole lot easier then!
Found it Looks a little bit larger but velcro should make it okay.
