TeamC TS4-TS4Pro SC thread >
Like Tree1Likes
Old 12-04-2013, 01:51 PM
  #1036
They look like a really good deal for under 300bucks..
But what about getting parts for them?
Is this an issue?
brushless55 is offline
Old 12-04-2013, 02:38 PM
  #1037
Trader Rating: 16 (100%+)
Is this an issue?
Shouldn't be a problem at all. I carry parts for it. I still race my TS4, so I carry pretty much everything for the truck.
J_Fowler is offline
Old 12-04-2013, 02:58 PM
  #1038
Thanks ..
Now would this be a good starter SCT ?
Old 12-04-2013, 07:37 PM
  #1039
Thanks ..
The TS4 platform is a great truck for racing. If you're just bashing, there may be better options. If you think it'll ever see a racetrack, the TS4 platform is a solid truck.
J_Fowler is offline
Old 12-09-2013, 02:11 AM
  #1040
tkge's Avatar
Trader Rating: 121 (100%+)
I have my truck completely built, and when doing a test run on the bench to get the esc setup, this truck is really loud. The gear mesh is set properly. I read back through this thread and seems that everyone says its loud if a bearing is going out, well its a brand new, and most of the noise is from the center diff. Its built right, and the bearings are fine. Any ideas? I have on order the main gear support, but has not come in yet, and I also already added the aluminum center diff brace that someone made on this site, it replaces the other plastic side of the center diff.
tkge is offline
Old 12-09-2013, 03:30 AM
  #1041
normal, carbon fiber center stiffener helps a little bit. I guess the plastic the spur gear is made of, some angle between center diff outdrive and the front middle CVD, together with the molded ring gears/ bevel gears for front and rear diff all contribute to the noise.
anyways, 4wd sct are always loud (we have a relatively small indoor track, and 4wd SCT races are our no-conversation period, nobody can hear others talking standing around the track). put some black grease between metal gears in the gearbox, and shim it right. it's fine.
nicholasxuu is offline
Old 12-09-2013, 09:11 AM
  #1042
Trader Rating: 28 (100%+)
i find on my truck if the bolts holding the centre diff in are too tight it binds the whole thing up and made a little extra noise so I run them more on the loose side, I have the CF brace though, but ya the truck is pretty loud like most 4wd
bobf24 is offline
Old 12-09-2013, 10:30 AM
  #1043
kamlooper's Avatar
Mantis works wrote some things in here about the noise, look through this thread. I believe its mostly shimming and quality of the center diff bearings. He got his very quiet as I recall but ya out of the box its brutal.
kamlooper is offline
Old 12-09-2013, 02:40 PM
  #1044
tkge's Avatar
Yeah I got it all shimmed right, and even put the ceramic bearings in the diffs for the pinion shaft. I may go ahead and replace the ones on the center just to be safe. I have yet to run the truck, so I will do that to get ready for this weekend. Thanks!
tkge is offline
Old 12-09-2013, 03:37 PM
  #1045
CarlCrocco's Avatar
Trader Rating: 91 (100%+)
Is this an issue?
Alot of places carry the parts, nitrohouse.com and amainhobbies do!!!
CarlCrocco is offline
Old 12-09-2013, 07:05 PM
  #1046
Sweet cuz I placed my order last Friday !!
Old 12-17-2013, 06:41 PM
  #1047
tkge's Avatar
So I ran my TS4 Pro for the first time this past weekend. It was a beast. Totally planted and very fast, could turn super tight turns and jumped great. I was loving this truck in practice for a couple battery packs. I could run 25 minutes easily with a Tekin RX8 and Pro4 4000kv motor using a 6600 mah battery and it was not even warm at the end of the run. Day ended on the third pack when the front right axle stub broke, not off a jump or a crash, but coming around a corner, and it was right about where the bearings sit in the hub. Kinda weird. I was done for the weekend, as I didn't order any of those as spares since I had the shocks limited with 5mm. Guess that was not enough or maybe it was just a weak part. I will get it back together and probably run it at the January Jam in Flowood MS next month. Truck was better to me than any other 4WD SC that I have had, and I have almost had them all........
tkge is offline
Old 12-18-2013, 05:48 AM
  #1048
Speed Freak RC's Avatar
Nice to hear, thinking of picking up one myself.
Speed Freak RC is offline
Old 12-18-2013, 06:31 AM
  #1049
symmetricon's Avatar
Trader Rating: 27 (100%+)
I loved mine while I had it, but I did find that the axles and the cast ring/pinion gears to be problematic.
symmetricon is offline
Old 12-20-2013, 06:20 PM
  #1050
kamlooper's Avatar
Great! How was the noise?
