TeamC TS4-TS4Pro SC thread >
Like Tree1Likes
Old 05-13-2013, 09:46 PM
  #901
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by cottonkidd View Post
yea I got you. and yes you are right about them not fitting well. I had to use the plastic shock holders and screw the adjustment nut all the way down just to hold them in. So what springs do you suggest I use after I make all the above adjustments? and do you think I should go back to stock springs for now and ditch the losi scte springs? And im not sure If the stock springs are medium or hard either. I don't think they are soft. Thanks again for all the very helpful info!
Follow the setup i linked a few pages ago, stock springs should be med i think.
TLR22T R springs fit the back yellows and whites work well
TLR22B R springs fit the front orange and silvers work well
MantisWorx is offline
Old 05-14-2013, 04:02 AM
  #902
Hoese37's Avatar
AE 50wt is 650cst. I could go to 40wt which is about 450cst. The ofna kit springs are the soft ones.
Hoese37 is offline
Old 05-15-2013, 08:39 PM
  #903
Im fixing to make my order on RCshox.com. I have a bottle of 450cst, 250cst, 15 and 7 dif oil, roll centers, and 2 stage pistons in my cart. Any thing else I really need?
cottonkidd is offline
Old 05-16-2013, 11:59 PM
  #904
I put my order in last night! I can't wait!
Old 05-18-2013, 02:12 PM
  #905
ok so I got some traxxas shock ends (5462) and they didn't fit. Didn't thread up the hole was slightly bigger. The bottom spring holders don't fir around the eyelets either. Any ideas? Did I get the wrong ones? I just assumed they were all the same for 10th scale. I have some eyelets from an older rustler and they fit but they are the same length it looks like. I also purchased a caliper, how do I measure droop again? Im still confused on that! thanks!
Old 05-18-2013, 05:58 PM
  #906
Hoese37's Avatar
I used the Losi SCTE shock ends.
Hoese37 is offline
Old 05-18-2013, 06:05 PM
  #907
Everything fit with no mods? Are they the snake length?
Old 05-18-2013, 08:30 PM
  #908
Hoese37's Avatar
Thyre about 2mm longer. They have a molded rib around the top that needs to be trimmed down to fit correctly, and I used the TS4 mounting ball in them rather than the Losi one.
Hoese37 is offline
Old 05-21-2013, 09:35 AM
  #909
I took a dremel and shaved down the traxxas eyelets and the stock spring holders fit now. I'm just waiting on my order from rcshox.com so I can put my truck back together. Every since I ordered it Marcus has disappeared! Hopefully by the time I get it he will be back cause I'm gonna need some setup help with all the stuff I ordered I'm sure. I have my truck tore down and all my difs and shocks cleaned out and ready to be filled back up! Any one have any good ideas to fix stripped out holes? My lower suspension arms are terrible! I have screws popping out a lot! I finally went to a bigger screw but when that's wore out I can't go bigger due to the eyelet hole not being big enough. Thanks again and I will have pictures and opinions once I get it all set up and get it out on the track!
Old 05-21-2013, 09:40 AM
  #910
MantisWorx's Avatar
LOL I am here man, just busy as heck!! I recently moved and couldnt find a complete batch of roll center plates that i had made so i had to make more.
Old 05-21-2013, 12:00 PM
  #911
Trader Rating: 16 (100%+)
After getting my TS4 together, I will say that I'm very happy with it. The stock setup was pretty good, and even better when I tuned it a little bit.
Overall, it's one of my favorites to drive. I still like my EVO better I believe.
J_Fowler is offline
Old 05-21-2013, 12:50 PM
  #912
Awesome! You know I was thinking, I wonder if he makes this stuff when its ordered. Or exactly what you said, I ordered them and there wasn't enough and you had to make more! I'm stoked about getting it! When you have time, I am
Curious how to measure my droop and when you say 1* camber, how do I measure that? Will the roll center plates do that for me?
Old 05-21-2013, 01:05 PM
  #913
Marcus can you get me the part number for those springs you were talking about. I want this thing perfectly setup to your setup when I drive it next time to see how it should feel and see if I like it.
Never mind I got them!
Old 05-21-2013, 01:09 PM
  #914
Hoese37's Avatar
Camber is adjusted by the top turnbuckle. you need a camber gauge to do it accurately. RPM makes a good one. The roll center plates just adjust height and how far in the camber link mounts. This all changes how the car handles. Droop is measured from the bottom of the lowest point of the chassis plate to the lowest point on the suspension arm.
Hoese37 is offline
Old 05-21-2013, 01:17 PM
  #915
Hoese37's Avatar
Rears
TLR5163 White
TLR5164 Yellow
Fronts
TLR5170 Orange
TLR5171 Silver
Hoese37 is offline
