Who's using the Mamba Max Pro in their 1/8th scale buggy?
#17
I run the Tekin 1900 with the Castle external bec, and hitec 7955 servo in the Eco with a 15 tooth pinion. Do you guys think that the MMP can this setup without any issues? Thanx for all the help
#18
I'm using a MMP with an external BEC on a Durango in 1400kv 5S and it works awesome. We even used it in real bad conditions (mud etc...) with no issue at all. You just need to make sure the fan is always running when you turn the car on and then you're good to go. It's cheaper, lighter, smaller more progressive than a mamba monster and does sensored too. Awesome deal, especially for high voltage setups so you can't go wrong with a BEC and a fan that works.
I had several RX8 and it isn't so reliable compared to the MMP. It's awesome when it works but I always ended with a problem with it. I'm still running one in my JQ but if it fails I'll use a SCT ESC of about 120A or so, MMP in it's short course version or an other one. If you have to go for 4S I would try a HW SCT 120A, it is smoother than the Xerun 150A
#19
Devi you have a Pm by me.
#21
Hobbyking.com
Go to the link below and make sure you are not logged-in if you have an account. Let it sit idle for a few minutes and you will get a pop-up offering it for 5% cheaper. Lists for $66.56,w/discount its $62.98. Add to cart, log-in and buy!
http://www.hobbyking.com/hobbyking/s...dProduct=10370
They used to have it in the USA warehouse, but i cant find the page.
#23
Hobbyking.com
