Kyosho Inferno VE Race Spec Gearing
Ive finally found that the stock SPUR gear is 46. I have a 21 Pinion gear, I guess what Im asking is where do I find the best setup?
I have a RX8 with Tekin 2650kv Motor in there. 46 spur, what pinion should I start with?
shud be 12t
I assume your running 4S?
I just traded for a VE race spec and know nothing about them. Mine has the Orion8 2050 stock system in it. Mine has a 46/13 combo, but unsure if thats factory. What thickness diff lube is a good start f/r for a large flowing dirt track? Also, where is the best place that stocks parts for it? I ordered a body from Amain but didnt see alot of parts for it there.
http://www.kyoshoamerica.com/Replace...rts_c_819.html
You can also try http://www.stormerhobbies.com and http://www.losipartshouse.com
