TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-16-2012, 09:25 AM
  #1111
Originally Posted by Grandturk View Post
Thats a good article. I guess I did pretty well. I totally forgot about the kingpins and the outer hinge pins though.
Probably front page linkage material.
However - unless I'm wrong - the 22SCT already comes with the carbide diff and thrust balls, the 3* LRC toe plate and 5* caster blocks.
It does come with the tungsten diff and thrust balls and the 3 deg lrc plate, but it comes with 10 deg front blocks.
hacker07 is offline
Old 08-16-2012, 09:29 AM
  #1112
Carranza76's Avatar
Originally Posted by Casper View Post
Yes the ultra digits last forever. In abrassive lower dust conditions they work great!!!!!
Is horizon the only place to get them?
Carranza76 is offline
Old 08-16-2012, 09:39 AM
  #1113
Carranza76's Avatar
I know a lot of people have been asking about the Ultra Digit tires we've seen on the 22SCT. Just got a set today and snapped some pics. I got a pair in green - super soft. Nice rubber feel. Very soft. The pins are like clustered step pins. Fairly long. I'm guessing these will be good on hard pack with fine dust. They have no inner ribbing and come with fairly firm nicely shaped open cell foam.
Where did you get yours? I just got a pair for a great price.
Old 08-16-2012, 09:50 AM
  #1114
Grandturk's Avatar
So it's 40 Deg Caster overall box stock? 30 Deg pivot plus 10 Deg block. And the team is running what 25 Deg pivot and 5 Deg blocks for 30 Deg total?
Grandturk is offline
Old 08-16-2012, 09:52 AM
  #1115
Casper's Avatar
Trader Rating: 34 (100%+)
The truck is setup out of the box a little more forgiving and for more med to lower bite. The team ran 25/5 at Hotrod which is high bite blue groove. Give the kit setup a try and tune from there
Casper is offline
  #1116
Grandturk's Avatar
I've got a track I could tear these up on in a single race night! .
Old 08-16-2012, 09:54 AM
  #1117
Grandturk's Avatar
That's what I was planning to do for the end of the outdoor season out here as most stuff is low bite. Once we go inside for the winter I'll play around with other settings.
That's assuming we get the truck before it starts snowing!
Old 08-16-2012, 10:02 AM
  #1118
Casper's Avatar
I would love to see that. I have run a set of ultra digits on my 8th scale on blue groove and got a full 4 days on them! Probably 5-6 practice runs, 4 rounds of quals and 3 mains. Still had good tread on them and the further down they get run the better they were!
Casper is offline
Old 08-16-2012, 10:06 AM
  #1119
Casper's Avatar
Anyplace that has a Horizon account should be able to order them for you!
Casper is offline
Old 08-16-2012, 10:11 AM
  #1120
Carranza76's Avatar
Sounds like these would be perfect for Pegasus?
Old 08-16-2012, 10:13 AM
  #1121
Casper's Avatar
Greens would work pretty good at pegasus when it is wet. Reds for dry. As long as the groove is not too dusty. I think a soft Panther raptor would be a better tire for Peg though
Casper is offline
Old 08-16-2012, 10:16 AM
  #1122
Carranza76's Avatar
I have a set Raptors for my 22 but I prefer the Jconcepts Hybrids as I get traction on all the conditions at peg with those.
I ordered a set of green digits off ebay and got a great deal so I will let you know how they work and yes I got the green compound.
Old 08-16-2012, 10:29 AM
  #1123
Casper's Avatar
The SC tread is quite a bit different then the buggy tread. Worth at least looking at. The tread has larger lugs then the 2wd.
http://panthertires.com/?page_id=42
I agree hybrids are a great tread pattern for conditions like Peg.
Casper is offline
Old 08-16-2012, 11:14 AM
  #1124
elecRC23's Avatar
What about for OCRC? What tires do you use for there?
elecRC23 is offline
Old 08-16-2012, 11:18 AM
  #1125
Casper's Avatar
I run Clay Panther Rattlers and have great success.
JC Gold Barcodes
Proline MC Suburbs are popular as well.
Casper is offline
