TLR 22SCT Thread (Check First Page for FAQ & INFO)
I would update the shocks to 2.0 and probably the bell crank. The others are more of a nice to have as far as I'm concerned, and would depend on the track you run at and how often you hit things.
Santa brought my son his first good rc, a 22sct RTC, and yesterday was his first time on a track. He had fun, and he learned that it is a lot harder than it looks.
If any spindle manufacturers out there are looking for a destructive product tester, my son is available for hire. :-) He broke 3 spindles in the front. So glad I bought the spares kit or it would have been a very short day. All three broke basically in half, right at the bearing support. All in all, it was a really fun afternoon.
When (not if) your steering slider develops a lot of slop you may want to consider the bell crank kit or the buggy 2.0 rack (cheaper but will still wear). Just keep in mind you will need the 2.0 caster blocks if you go to the bell cranks.
Depending on the surface you are running the gear diff that comes with the RTC will not perform as well as a ball diff. Just saying that most kids (mine included) don't have the best throttle smoothness and the gear diff can limit rear traction (spin out) on loose surfaces.
Yes the solid king pins that come with the TiCN hinge pin kit is one of the upgrades that should be done on the RTC truck along with the bell crank steering like E-Mann said.
Altho the ball diff is nice, I think with the sensored motor and adjusting the slipper properly, you can get your take-offs pretty smooth. Tires play the biggest role in getting around a track so that should be your next upgrade IMO.
I'm in the same boat. Already dropped a bunch of cash in my truck to upgrade the 1.0 to all 2.0 parts as well as roots 2014 setup. This will be my third major overhaul of the truck.
For instance the 22sct bell crank system, I see that on my short list. Biven said he took the same upgrade route I am looking to take, I would like to know what all upgrades from the sct 2.0 that he performed. I will buy a new chassis before I buy the new kit.
My chassis is coming in the third shipment!
Ok....I've seen this discussed before, but I wanted to confirm something. This past weekend, my first time out racing on a tight indoor carpet track, I broke 3 spindles on my otherwise stock 22sct. From what I see posted here, replacing the hinge/king pin screws w/full length pins (TLR234034) would (for the most part)!resolve this issue. Is this the recommended path forward, or should I upgrade to 2.0 parts at the same time? If so, what short list of part #'s would I need?
As for the front hinge pins staying in, there are two allen set screws in the kick block that secure them. Make sure you remove / back out those before trying to remove or reinstall the new ones that come in the package (although these are really not needed as they just changed the coating on the new ones).
I have the 1.0 SCT and just ordered the Exotek bell crank steering. It was only $13 more than the plastic 2.0 bell crank and you don't have to change anything else. I see a lot of people saying they upgraded to the plastic 2.0 version but haven't heard much about this. I'm kinda wondering why I haven't seen more about this on here.
If you are looking to improve reliability and performance on the front, then getting the bell crank kit (TLR231027) with the 2.0 caster blocks (use the 0 degrees in the pack TLR234006) is your best bet. The bell crank kit comes with spindles so if you buy spares (shouldnt need them) make sure to get TLR234029. This is not the full 2.0 front conversion but is the best starting point for performance on a 1.0.
I thought this kit was giving me a outer hinge pin to replace the screws AND a king pin for mounting the spindle to the caster block. Obviously I was wrong.
If I wanted threaded kingpins And outer hinge pins, which part number would I I've for those? (Considering I'll upgrade to 2.0 parts)
Thx for the help.
Ok. I'll start with the steering upgrades.....might was we'll since I need replacements anyway.
Thx for the help.
Thx for the help.
Are you maybe thinking that the bellcrank system that E-Mann suggested includes the king and hinge pins?
TLRacing
Thx for the help.
Thx for the help.
