TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-30-2014, 11:27 AM
  #10231
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by asw7576 View Post
Hello,
I want to know more about Team Losi Racing 22 SCT 2WD.
1. Is this car easy to drive for asphalt on road racing ? In my country, on-road short course racing is becoming more popular. Racers usually piloting 4wd team losi scte and tekno racing 4wd. I want to use 22 SCT 2WD for simplicity reason. Am I going to be disappointed chosing 2WD truck ?
2. As part of on-road SC racing regulations in here ..... Racers are required to use 1/8 On Road GT Tires. Usually they use Sweep Racing tires. Therefore , 17mm Hex Adapter must be use for aforementioned tires. Is this fit ? MIP 17mm Hex Adapter Kit, Traxxas Slash 2wd #10114.
3. Do u have any suspension setup suggestions for asphalt racing ? Should I use middle or rear motor mount location ? I prefer to have stable rear end rather than fish tailing rear end.
Thank you for enlightening me.
Proline has some tires.
http://prolineracing.com/street-fighter/
JC has a similar tire as well
http://jconcepts.net/shop/glocs-blac...2-sct-premount
If the track is prepared Panther Makes slicks!
http://www.panthertires.com/store/in...&product_id=68
Casper is offline
Old 08-30-2014, 05:18 PM
  #10232
MD
MD's Avatar
Trader Rating: 130 (100%+)
I have used the Proline Street Fighter in parking lot racing and they work very well. I have used the GLoc tread pattern on tires for the 4WD Stampede and they were very good.
MD is offline
Old 09-01-2014, 01:43 AM
  #10233
Trader Rating: 136 (98%+)
Will sc10 hex wheels fit sorry if its a dumb question have not had a losi in about 10 years
ashxxx is offline
Old 09-01-2014, 08:46 AM
  #10234
The hex is the same but the offset is different. So SC10 wheels will bolt on to the 22sct but they would stick out past the body.
fantomdude is offline
Old 09-01-2014, 08:53 AM
  #10235
Trader Rating: 21 (100%+)
If you have the standard 0 offset rims they will, but if you have the +3 rims then they will stick out of the body a little.
Brian L is offline
Old 09-03-2014, 11:05 PM
  #10236
Jake S's Avatar
Trader Rating: 67 (93%+)
how tight are people setting their slippers? (how mm from flush nut)
Jake S is offline
Old 09-05-2014, 12:54 PM
  #10237
Jake S's Avatar
have noticed my truck had the slipper friction pads (not hds) so i have an hds spur otw to run the hds pads.
not sure the small pads are enough for mod sct.
Jake S is offline
Old 09-05-2014, 02:16 PM
  #10238
Laker67's Avatar
Trader Rating: 69 (100%+)
I run the SC10 +3 offset wheels on my 22SCT and they tuck just fine. On the SCTE on the other hand the do stick out past the body.
Laker67 is offline
Old 09-06-2014, 07:15 PM
  #10239
Whats the best body for the sct thats the smallest some body seem to be so much wider than some.
ashxxx is offline
Old 09-06-2014, 08:13 PM
  #10240
sduffy77's Avatar
I love the new Proline EVO body. I got it for both my 2wd and my 4x4.
sduffy77 is offline
Old 09-07-2014, 07:05 PM
  #10241
got a issue with the left rear drive shaft it keeps coming apart and blowing out after only 2 to 6 mins even tried ae ones only lasted 7 mins even thread lock and heat tube over the pin still flys apart what is going on here.
ashxxx is offline
Old 09-08-2014, 05:40 AM
  #10242
Trader Rating: 114 (100%+)
The kit body is really good. Any of the JC Hiflow work pretty well.
You could put a small notch in the pin where the set screw sets using a dremel. Clean all the parts especially the grub screw. Use good Loctite. I never had issues when I ran mine.
kwiksi is offline
Old 09-08-2014, 11:34 AM
  #10243
ridered4life250's Avatar
Has anyone been having binding issues with there Exotek bellcrank upgrade? I have a Spektrum 6040 and at full right turn, it binds. I get maybe 10% more left turn than right turn. I will take some pics when I get home but I need to know if anyone else has every experienced this issue. The actual TLR servo horn binds on the link that goes between the servo and the bellcrank. In Exotek’s directions, it shows using the new steering link off the TLR 22 2.0 (similar to team associated’s on the B5), but I cant buy just that link because TLR blows and only sells stuff as massive kits (unlink AE where you can buy just spring cups and don’t need to buy half the da*n shock all over again).
Any help would be appreciated.
ridered4life250 is offline
Old 09-08-2014, 12:08 PM
  #10244
sduffy77's Avatar
Did you order the ExoTek servo mounts?
it shows that you'll need to install the servo from behind:
https://app.box.com/s/ojr0u3mj9ehez4b32tl9
sduffy77 is offline
Old 09-08-2014, 12:27 PM
  #10245
Trader Rating: 29 (100%+)
You don't have to use the 2.0 steering link/ends....did you follow Step 5 of the Exotek instructions?
https://app.box.com/s/mxr1jf1khvj77g23allb
joncmack is offline
