TLR 22SCT Thread (Check First Page for FAQ & INFO)
Yeah, please post a chart or parts listing to upgrade. particularly suspension pieces. Does the new chassis retain the same screw hole locations? Can I keep using my old chassis and still mount the new battery tray system?
I absolutely love my SCT, I can't wait for this truck to come out and compare the two.
I am curious why its only offered in a RM configuration?
We have found that the vast majority use an SC in RM config today and it make it so that vast majority don't have to spend an extra $35 on the kit. Those that want to play with mid motor can buy the conversion kit for that same $35.
with revised body mounts it appears, will our current body hole patterns line right up and drop right on??
also, why still using the wider rear alum hex on back of truck instead of the narrow tlr2930 alum rear hex?
very nice that kit will include the TINI pin kit. I already have that kit on my current 22, nice pieces. also nice to see other alum upgrades come with kit.
We tested a number of different hex widths and hubs and arms lengths and this is the hex width that was determined to work the best.
Truck looks great, just hope you can find a faster boat to ship it on.
TLRacing
Frank, does it still use the same rear arms and axles or were they changed to reflect how you have your truck?
If not, I basically have built this truck previously using all the 2.0 parts and the Exotek ver. 2 steering bellcrank and can attest that the changes do make the truck handle better.
The front spindles and carriers are the updated 2.0 parts but the spindles are the ones made for the bellcranks. The arm is new.
The rear arm and hub are new and I think the axle is a slightly different length but Frank may have to chime in there. (he is getting on a plane so I figured I would answer what I can).
Just overall, this truck is VERY good. Almost every suspension part is updated on it, the truck is wider front and rear, the shocks are new lengths so the truck lands better, and on and on...
New axle and CVA bone length to accommodate the new rear arm length and hub/hex/wheel offset
Thanks for the help today Ryan
gearing difference 17.5
Hello guys, i have a 22 2.0 and 22sct and was wondering about the gearing differences i beleive both have the same transmission rations, but I am reading that the buggy should be a 30/70 gearing setup. The SCT however is a higher spur combo i think its 76 or 80 tooth. why the large difference, is it because of the weight differences
I would imagine it comes with an aluminum top shaft and the schelle slipper will fit being a 2.0? Don't think I've seen it anywhere, has there been any work done to the tranny on the MM kit? I'm assuming that most aftermarket parts will fit except the MIP pucks?!?!
ok so when does everyone think i can actaully order the SCT22 2.0? I am selling my sc10.2 at the monent and want to know how long i have to run my buggy for before i can run SCT again.
You can already place an order for the truck now. It is not available to ship until the middle of November.
When are you guys going to an intro video and compare the two trucks like you have your other 2.0 cars?
Hey guys what do you think..... Dynamite platinum vs hobbywing just stock?
