TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 03-19-2014, 06:42 PM
  #9691
RacrX's Avatar
Originally Posted by sduffy77 View Post
So I build my first ball diff last night (the one that came in the kit) which took longer than it probably should have.
My question is, is the MIP super diff any better than the kit supplied?
Does the Team Associated diff screw/nut make much difference?
If you have to build the ultimate diff, what would you use?
I run the MIP screw with the Losi aluminum nut, and with the Losi aluminum nut I can change the captured nylok nut every time I rebuild. B-Fast rings and balls and an Avid pre built thrust bearing. Now that's what I consider the ultimate diff lol.
RacrX is offline
Old 03-19-2014, 07:10 PM
  #9692
RacrX's Avatar
My problem is with the Avid Triad Slipper assembly. I just installed one but haven't ran it yet. I bought the Avid top shaft and I don't think something is right and I'm 100% sure it's together right. The wide part of the top shaft that engages the plates stops and is completely flush with the last plate. It does not stick out past the plate at all to engage the spring and center it. The metal cap that sits behind the nut centers the front of the spring but it's not enough. When I tighten down the spring it's not centered on the plate which is not good nor can it be right. It needs to be centered for balance and to keep the spring from leaning over. The reason I bought the top shaft is because the Losi factory one did not fit right and hold the rear of the spring? I contacted Avid but no reply, can anyone running this help?
RacrX is offline
Old 03-19-2014, 07:15 PM
  #9693
RacrX's Avatar
I seen a pic Randy pike posted in the Triad thread but it looks like he is running the Losi top shaft as the threads on the shaft in the pic are black which the losi's are and the avid aren't. He is also running a washer against the last plate before the spring which would be needed on the Losi shaft and not the avid one.
RacrX is offline
Old 03-19-2014, 07:32 PM
  #9694
Chr1s's Avatar
The out drives on my MIP diff wore 3x as fast as the TLR diff. I don't know if mine was not hardened properly or if they are all like that. As someone else said the MIP rebuild kits are cheap. The AE diff bolt is definitely worth having in the pit box in case the stock one snaps. I'm a fan of the new style caged thrust bearings, either from casper or avid. Diff ball material seems to be a personal preference for most people. I usually go with steel cause its cheap and it does the job. Proper break in is key!
Chr1s is offline
Old 03-19-2014, 08:34 PM
  #9695
Bivens's Avatar
Stock losi out drives with BFast thrust bearing, rings, and balls.....follow the TLR assembly and breakin video....smooth and long lasting...
Bivens is offline
Old 03-20-2014, 07:21 AM
  #9696
sduffy77's Avatar
Trader Rating: 21 (100%+)
Thanks again for all the help Chris. I got the diff all setup and broke in last night. I did end up having to tighten it a 1/4 turn and loosen the slipper a bit but after that it works great.
Now to deal with the traction issues from going from 17.5 to 10.5 :-D
sduffy77 is offline
Old 03-20-2014, 08:58 AM
  #9697
Mclogo's Avatar
So finally I also ordered a 22SCT
I've read a lot in the first post/faq section regarding the 22SCT, one thing that I did not see was regarding the body holes.
Does the body fit both SCTE 2.0 and 22SCT regarding the holes for the body posts or do I need to have 2 different bodies?
Mclogo is offline
Old 03-20-2014, 09:07 AM
  #9698
Chr1s's Avatar
the body posts don't line up unfortunately.
Chr1s is offline
Old 03-20-2014, 09:19 AM
  #9699
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Do you know the part # for the avid thrust bearing?
DriveItLikeYSIT is offline
Old 03-20-2014, 09:51 AM
  #9700
Casper's Avatar
Trader Rating: 34 (100%+)
Casper-RC.com
The ceramic balls with the grooved washers typically last multiple diff rebuilds so even with the slight extra cost of going to the ceramic bearing the value is surely there.
Also the on-line support is better!
Casper is offline
Old 03-20-2014, 09:57 AM
  #9701
Mclogo's Avatar
Thanks Chr1s
Mclogo is offline
Old 03-20-2014, 10:08 AM
  #9702
Originally Posted by Casper View Post
Casper-RC.com
Thanks for the follow-up Casper!!!
Old 03-20-2014, 11:35 AM
  #9703
sduffy77's Avatar
Casper-RC.com
I just ordered one!
also ordered the TLR alum nut holder and nut.
Is one screw better than another?
sduffy77 is offline
Old 03-20-2014, 12:44 PM
  #9704
Casper's Avatar
I just ordered one!
The Gen 2 nuts have a metal insert in them and work GREAT. No need for the alum holder but it works well also and if you can find repalcement 2mm nuts those alum holders are pretty cool.
Casper is offline
Old 03-20-2014, 12:48 PM
  #9705
Casper's Avatar
I just ordered one!
Which screws we talking about AE vs TLR?
The AE one is slightly bigger diam and would be stronger but you have to use the AE nut as the thread is different.
Most of the time the TLR works just fine although I will admit I have broken a few over the years of running these things. Almost always on very high bite tracks.
Casper is offline
