TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 03-06-2014, 09:58 AM
  #9601
wreckya's Avatar
Originally Posted by darkstar1974 View Post
Yup. That's what I'm going to try tonight. Should keep the rear end width the same as 22 2.0 axles w/ standard buggy hex. I'm assuming Frank uses the buggy hex on the 22 2.0 axle b/c they can get closer to the rear hub and not create that slop.
I just checked back and Frank says he's using the 22 2.0 axles b/c he thinks they rotate a little better and don't bind as much as the 22 SCT's
That's weird, I thought the axles were exactly the same with the 22 2.0 just having a longer thread on it. Don't see how one would bind more than the other but hope that's the case because it cost me 35 bucks for a set of axles.
wreckya is offline
Old 03-06-2014, 10:30 AM
  #9602
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
The CVA always creates bind, and the distance from the CVA pin and slug to the inner and outer hinge pins can affect the cars handling greatly.
Frank Root is offline
Old 03-06-2014, 12:51 PM
  #9603
wreckya's Avatar
Thanks for clearing that up boss.
wreckya is offline
Old 03-06-2014, 01:09 PM
  #9604
Why are so many of the set-up sheets using buggy rear springs? Why use those over the truck springs?
explorerlyon is offline
Old 03-06-2014, 01:53 PM
  #9605
goehm's Avatar
Trader Rating: 45 (100%+)
All things being equal except for the length, a shorter spring will reach full compression quicker (coil bind). Springs naturally get more firm near full compression. So running a short spring will make it a bit more progressive (essentially the same rates when the springs are fully extended, but shorter springs gets firmer quicker).
goehm is offline
Old 03-06-2014, 02:28 PM
  #9606
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
I thought buggy springs were progressive and truck springs were linear ?
OfnaJoe is offline
Old 03-06-2014, 03:24 PM
  #9607
AndrewTom's Avatar
i dont think its like that.
the buggy spring is just more progressive then a truck spring.
and the LF are designed to be less progressive,
but i dont know if they are less progressive then the truck springs, Frank or Casper may know the answer.
AndrewTom is offline
Old 03-06-2014, 03:48 PM
  #9608
Chr1s's Avatar
read the note on the spring chart
http://losiracing.blogspot.com/2012/...ing-chart.html
Chr1s is offline
Old 03-06-2014, 08:02 PM
  #9609
Originally Posted by Chr1s View Post
Reading the note on the chart, the buggy springs will be stiffer. How is this different than just going to one step harder spring? I am just trying to understand how changing springs affects things.
Old 03-06-2014, 08:15 PM
  #9610
Loose spring at full droop........????
I have my front ride height set at 26.5mm, shock unscrewed 3 turns, no limiters, blue truck springs (dunford/casper setup). When the front arms are at full droop and the shock extended, the spring is under no tension and actually has 2mm of vertical play. Seems like the spring can become unseated in the air. Is this ok?
Old 03-06-2014, 08:40 PM
  #9611
wreckya's Avatar
So running a short spring will make it progressive, yeah but I thought buggy springs were progressive And you goehm just won what's behind door number one lol. As far as the shock being fully extended allowing the spring to become unseated I also wonder about that.
wreckya is offline
Old 03-07-2014, 02:08 AM
  #9612
Mclogo's Avatar
I will probably pick up a 22SCT in a few month... Is it possible that there will be a 2.0 update soon (this year)?
Mclogo is offline
Old 03-07-2014, 05:21 AM
  #9613
WIGMAN's Avatar
Trader Rating: 19 (100%+)
According to what Frank Root has posted numerous times on this thread the answer unfortunately a big fat no.
WIGMAN is offline
Old 03-07-2014, 06:50 AM
  #9614
Mclogo's Avatar
Thanks! Sorry for asking again
I hope there is at least an update to the optional gear diff... as I would plan to use it a lot for high traction carpet/astro
Mclogo is offline
Old 03-07-2014, 09:48 AM
  #9615
WIGMAN's Avatar
No need to be sorry, heck hopefully enough people will e-mail them and ask in forums that they will take note that we would lke to see an updated kit like a 2.0
I know Frank is reading this too so........maybe a hint will get dropped by accident or something....LOL
WIGMAN is offline
