TLR 22SCT Thread (Check First Page for FAQ & INFO)
#9541
I've been holding off on buying the 22SCT to see if they release a 2.0 version. I haven't seen any news on it, but a few of the big online shops had them on sale like they do sometimes to make way for the new version.
Am I just holding my breath for nothing? Seems like whenever I buy something the "new and improved" version gets released a week later.
#9542
22.2 Axle spacer on FR's Set Up
When using the 22.2 axle there is a spacer that should be used on the axle before assembling to the hub, otherwise the axle has slop. I think I read in here somewhere that Frank said not to use it. If you use the 22.2 axle with shim it's the same as the 22sct axle. So why the need for 22.2 axles?
#9543
Frank Root advised the thread NOT to hold our breath for a 2.0 anytime soon.....posted about 1 month or so ago...
Go for it...never a better deal than you have access to now....
#9544
Shoot, the one time I wait to buy something... used to be $219 special on Amain, now it's back up to $259
Well, flying season is coming up anyway and running/cleaning/maintaining my 1/8 buggy keeps me plenty busy as it is. Gonna wait to see if another sale comes up now.
#9545
Ok so has anyone tried just changing the rear to the new 2014 Franks setup without changing the front? If so did it help with rear traction? My truck turns great and I have aluminum spindles and really don't want to change the front parts. But I'm wondering if they go hand in hand and if you don't change the front doing the rear will not benefit in any way. Can anyone contest to this? Also does anyone now if Frank left the 1mm shim to raise the tranny in when doing this 2014 upgrade to the rear?
#9546
Does anyone know what size turnbuckles Frank switched to accommodate for the 22T bones and arms?
#9547
I currently have the aluminum rear hubs does anyone know if its a must to update to the 22.0 rear hubs when changing to his 2014 setup?
#9548
#9549
Thanks.
#9550
I haven't run anything other than the 2.0 front end on this truck, but based off what I learned from the buggy, you definitely want to update. The trucks already have that 'I wanna tip over and spin' feel. The 1.0 front end makes them dump even more onto the outside rear tire.
#9551
ok, cant get some help on what page to look for the necessary upgrade parts needed for the truck? I just bought the kit and will be running it in the stock outdoor class for the summer. I would like to only build it once for now. I've seen and talked to people about putting the 22t front in instead of the standard one. Is there any full replacement kit # for that or is there a list on here with all the part numbers? I didn't notice any on the first page.
Thanks in advance.
Thanks in advance.
#9552
What is left besides the parts u posted? Hexes and axels? U pretty much covered it with those parts.
#9553
http://www.amain.com/product_info.ph...rnbuckle-Set-2
#9554
Since it's 22T arms, I'd assume they're the matching 22T turnbuckles:
#9555
