TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-09-2014, 06:48 AM
  #9076
Originally Posted by OfnaJoe View Post
Bog Bore= when you go mud bogging in Daddys new Porsche and get bored with it being stuck and walk home.
lol... daddy must have a lot of money. must be nice. if i would of done that with my dads chevy truck back in my young days i would have got my butt beat....lol
jhue73 is offline
Old 01-09-2014, 06:57 AM
  #9077
Originally Posted by WIGMAN View Post
The 22T shocks are 12mm big bore shocks, they are bigger than the xxx-sct shocks, the big bore springs are cheap and will not rub.
nothing is cheap in rc. but thanks for the help.
jhue73 is offline
Old 01-09-2014, 08:38 AM
  #9078
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Brian L View Post
No spacer on inside of axle or can you use the 1.0 axle also? 1.7 piston in front and 1.6 in rear?
Wow, I've made 3 mistakes on this setup sheet, so sorry guys. The front pistons are 1.5mm pistons, TLR233008. So sorry, hope this didn't screw anyone up yet. I already sent the fit to the Web Content team, hopefully will be updated in a hour or 2.
Frank
Frank Root is offline
Old 01-09-2014, 08:44 AM
  #9079
Carranza76's Avatar
If your dads Chevy truck would have gotten stuck in that mud I would of sold it and bought a Ford!. lol
Carranza76 is offline
Old 01-09-2014, 08:52 AM
  #9080
dirt42fan's Avatar
Trader Rating: 151 (100%+)
Hey Frank
Just one question. It says on both ends to unscrew the shaft ends 5 turns. That sure dont leave many threads inside the end does it? 5 full turns around?
dirt42fan is offline
Old 01-09-2014, 08:56 AM
  #9081
TLRacing
Frank Root's Avatar
Originally Posted by dirt42fan View Post
Hey Frank
There is an issue with the sheet, that when you enter a value in the front or rear box, it shows up in the other box as well. In the other notes for the front end (under the pictures), it details what front droop to run.
Old 01-09-2014, 09:08 AM
  #9082
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
That's what I was thinking too!
OfnaJoe is offline
Old 01-09-2014, 10:53 AM
  #9083
i would walk before i would own a ford....lol
jhue73 is offline
Old 01-09-2014, 10:56 AM
  #9084
Carranza76's Avatar
Well if you own a Chevy I hope you have a great pair of walking shoes!
Old 01-09-2014, 11:15 AM
  #9085
OfnaJoe's Avatar
And usually does. At least Chevys come with heated tailgates so your hands don't get cold while pushing them..............
OfnaJoe is offline
Old 01-09-2014, 11:16 AM
  #9086
a chevy is what i own, never had to walk and its got about 300,000 miles on it. but i have worked on a bunch of fords.....lol
jhue73 is offline
Old 01-09-2014, 10:00 PM
  #9087
any of you Ford or chevy guys ever work on TLR's?
AlwaysLOSI is offline
Old 01-10-2014, 07:11 AM
  #9088
Carranza76's Avatar
Rarely, i took my 22 2.0 from a high bite indoor clay track to a outdoor medium bite track and made two changes, tired and went from 2MM spacer on the front camber block to 1 MM and it ran great.
No need to work on a car that much when it runs great from track to track. I look at building a diff like changing your oil no matter what it will have to be done on the regular are you vehicle will run like crap.
Old 01-10-2014, 01:10 PM
  #9089
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Do the kit ball diffs come with the carbide diff balls or are they optional? I'm going to take a crack at building a ball diff and compare it with my 15k gear diff on a MM truck. Hope I don't mess it up after break in.
BOLISARIO is offline
Old 01-10-2014, 02:19 PM
  #9090
Casper's Avatar
Trader Rating: 34 (100%+)
They come with carbide balls.
Another great option for a longer lasting ball diff is the Casper-RC grooved washer ceramic thrust bearing
V
Casper is offline
