TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-08-2014, 01:52 PM
  #9061
AndrewTom's Avatar
Originally Posted by RCW View Post
Has anyone ran the 22T rear shocks with the 22t arms and shafts? I ask because it looks like everyone is looking for more droop.
I would think that would a better option then 5 turns out and 3mm up travel limiting with the stock shock body. the 22T and 22SCT share the same length shock shaft, so just shock bodies would need to be changed.
from just eyeballing my 22t and Sct, i would guess ~2mm longer body on the T, which is close to what franks setup calls for.
EDIT: buggy Red rear spring seems a little stiff.
AndrewTom is offline
Old 01-08-2014, 03:52 PM
  #9062
does anyone know the inner diameter of the tlr shock springs? i have searched everywhere. i am using 22t shocks on the rear of my traxxas slash and the traxxas springs are rubbing the threads on the shock body. any help would be appreciated.
jhue73 is offline
Old 01-08-2014, 05:07 PM
  #9063
WIGMAN's Avatar
Trader Rating: 19 (100%+)
Not trying to be a smart A$$ here but why don't you just get some Losi Springs?
WIGMAN is offline
Old 01-08-2014, 05:17 PM
  #9064
i think losi springs are the same as traxxas if not a little smaller diameter, at least the ones on my xxx-sct are. so i assume the tlr springs are bigger.
jhue73 is offline
Old 01-08-2014, 05:21 PM
  #9065
im a tightwad.....lol. i guess my dremel will do for now....lol
jhue73 is offline
Old 01-08-2014, 06:25 PM
  #9066
Trader Rating: 21 (100%+)
Originally Posted by Frank Root View Post
22 2.0 Hub and 22 2.0 axle.
No spacer on inside of axle or can you use the 1.0 axle also? 1.7 piston in front and 1.6 in rear?
Brian L is offline
Old 01-08-2014, 06:30 PM
  #9067
AndrewTom's Avatar
any big bore spring is larger then the standard bore spring.
Old 01-08-2014, 06:32 PM
  #9068
AndrewTom's Avatar
they are not that expensive. if you complaining about Kyosho springs, that would be different.... but TLR springs...i dont see it.
Old 01-08-2014, 06:35 PM
  #9069
Originally Posted by AndrewTom View Post
any bog bore spring is larger then the standard bore spring.
bog bore?
jhue73 is offline
Old 01-08-2014, 06:42 PM
  #9070
i was joking, but i do have a bunch of other springs laying around from different kits that rub on the threads of the 22 shock bodies.
jhue73 is offline
Old 01-09-2014, 02:12 AM
  #9071
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
bog bore?
Bog Bore= when you go mud bogging in Daddys new Porsche and get bored with it being stuck and walk home.
OfnaJoe is offline
Old 01-09-2014, 04:01 AM
  #9072
WIGMAN's Avatar
The 22T shocks are 12mm big bore shocks, they are bigger than the xxx-sct shocks, the big bore springs are cheap and will not rub.
WIGMAN is offline
Old 01-09-2014, 05:48 AM
  #9073
dirt42fan's Avatar
Trader Rating: 151 (100%+)
Originally Posted by cptxaggie View Post
Not sure if this has been posted or not...the Frank Root's 22 SCT RM set-up using some 22 2.0 and 22T components
Frank Root 22SCT Standard Setup 2014 Indoor
"Frank has been running quite a bit of 2wd Short Course lately, really focusing on developing a new setup for the 22SCT. Trying to find a setup that fit his driving style, but also that of some of his stock class club racing friends (Lee Caldwell and Craig Hammon), they worked to find an easy to drive, but quick setup that had a great natural balance. Frank thinks he's found it with the setup above. It is easy to drive, and not only Frank, but Craig and Lee, are turning some quick laps with it. Some parts from the 22 2.0 and 22T are required, but they are well worth it. Give it a shot and let us know what you think!"
I get this error. is there a different link?
We're Sorry!
An error has occurred on our site. This error has been logged and will be investigated by our personnel.
dirt42fan is offline
Old 01-09-2014, 06:13 AM
  #9074
Regional Moderator
cptxaggie's Avatar
We're Sorry!
Sorry, I messed up the original link and left a https:// at the end of the url. Here is the correct link.
cptxaggie is offline
Old 01-09-2014, 06:21 AM
  #9075
dirt42fan's Avatar
Thanks!
Just one question. It says on both ends to unscrew the shaft ends 5 turns. That sure dont leave many threads inside the end does it? 5 full turns around?
