TLR 22SCT Thread (Check First Page for FAQ & INFO)
#9031
You could also drop 3 teeth or so on your pinion to achieve the same gearing. I prefer the larger spur on the SCT.....but have tried both ways.
#9032
Short answer, larger spur or smaller pinion for more bottom.
I have a setup at www.casper-rc.com that a lot of poeple have had positive feedback on if you want to check it out.
#9034
In all honesty a good RM setup is not a bad starting point for a MM setup. Flip the motor around and give it a shot. We are typically lightening up the rear shocks spring and oil a little and maybe a shock angle change but if you like your RM setup you will be close in a MM setup. At least close enough to have a good base.
#9035
One thin I noticed and not sure what to do here, on the hinge pin block in the manuel it says to add the 2 degree insert in the block. But the tranny does not sit flush on top. Not sure if I am explaining this correctly. I will try to get a screen shot from the manual. I am still getting binding in the tranny also which is causing overheating issues.
Gonna try to a tear down and rebuild this week some time.
Edit: Parts number TLR2044 is what I am talking about.
#9036
I kept your RM set up and switched to MM. I added the TLR weight kit also.
#9037
In MM the tranny is not suppose to sit flush, you have to change that insert when you go from RM to MM, the MM has bigger holes where the screw goes through it and screws into the tranny, the RM insert the screw screws into it to secure the toe block as the tranny does not sit ontop of the block in RM form.
#9039
Edit:
these: http://www.amainhobbies.com/product_...d-Set-4-TLR-22
#9040
Try the ones from the 22 2.0 those go through the front caster block by about 5 mm or so.
Edit:
Edit:
#9041
Yeah just checked and I thought it was the fromt camber block he was referring to!
http://www.amainhobbies.com/product_...ock-Kit-TLR-22
#9043
I have tried the Casper set up. I didn't know if there was a newer version that people liked out there. My current set up is a hrc set up I like just always changing things.
#9045
Hello
I am sure this has been covered but I want to ask anyhow. I just picked up a 2.0 rack. Does this just bolt in without anything else needing done?
Can I still use the existing ball cup servo linkage or do I need to use the one included?
