TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 11-20-2013, 03:45 PM
  #8686
klaymon's Avatar
Trader Rating: 71 (100%+)
Originally Posted by wyckoff View Post
Ok have a question I have these shock shafts for a 22sct item numbers TLR233002 and TLR233000 These are the new TiCN shocks shaft but these shafts are shorter then the ones that come in the kit. Anyone have the right numbers
Thank You
TLR233004 Rear
TLR233001 Front
klaymon is offline
Old 11-20-2013, 03:57 PM
  #8687
Casper's Avatar
Trader Rating: 34 (100%+)
Thank You
TLR233001 front and TLR233004 Rear
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-tlr-shock-shafts.jpg
Casper is offline
Old 11-20-2013, 04:18 PM
  #8688
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Would a Tekin RS Gen2 and 8.5 Gen2 push this truck OK? I'm tired of waiting on the RSX to be released. Or should I just go ahead and get another RX8 Gen2 and a 7.5 or 6.5? I run a a high bite carpet track so I can lay down the power
OfnaJoe is offline
Old 11-20-2013, 04:33 PM
  #8689
drepus's Avatar
The rsx/8.5 would be a nice combo on dirt or on a smaller carpet track. If the carpet track is medium to large then you will be wanting moar powah!
drepus is offline
Old 11-20-2013, 05:00 PM
  #8690
WIGMAN's Avatar
Trader Rating: 19 (100%+)
The 8.5 will be just fine, most people that run anything more can't drive it anyway. I run an 8.5 in one of mine and I have way more than enough power everywhere I have run.
If you want to save a little check out the SMC 8.5 at www.smc-racing.net
They are $50 and I see no difference on track between my Gen2 8.5 and the smc. The smc is 1/2 the price.
WIGMAN is offline
Old 11-20-2013, 05:07 PM
  #8691
Casper's Avatar
I run that combo in my SCT and it works great. If you need more power just boost it a little. No problems with heat or power from me.
Casper is offline
Old 11-20-2013, 05:20 PM
  #8692
kmh038's Avatar
Originally Posted by Carranza76 View Post
The Puck system uses a hard plastic replaceable piece that screws into the pin.
See attached picture, it is installed in my 22 2.0 buggy
Yea I knew the PUCk system you can replace the plastic. I was curious whether or not you can replace the pins that go into the out drives on the factory axles or do you have to just buy new axles.
kmh038 is offline
Old 11-20-2013, 05:24 PM
  #8693
OfnaJoe's Avatar
Thanks guys, and yes. Real small carpet track. I was thinking the 8.5 was like 5350kv or so? I ran a PRO2 5100 in my 2WD SC10 and it was a HOSS, so was thinking the 8.5 would be more "Hossier"
OfnaJoe is offline
Old 11-20-2013, 05:26 PM
  #8694
AndrewTom's Avatar
Originally Posted by kmh038 View Post
Yea I knew the PUCk system you can replace the plastic. I was curious whether or not you can replace the drive pins on the factory axles or do you have to just buy new axles.
the drive pin in the CVA or the hex?
for the CVA you can just get the rebuild kit
the hexes as i remember are backordered.
AndrewTom is offline
Old 11-20-2013, 05:32 PM
  #8695
WIGMAN's Avatar
I run on a small carpet track once or twice a month, I run a 13.5, it works just fine and I can carry more corner speed with it than most....running mid-motor as well, my setup is on the first page.
WIGMAN is offline
Old 11-20-2013, 08:46 PM
  #8696
Kaw1000's Avatar
Guys,
I seem to be having problems with the pin that attaches the dogbone to the rear hub. Keeps falling out. Any fixes or mods this annoying problem? Thanks
Kaw1000 is offline
Old 11-20-2013, 09:16 PM
  #8697
AndrewTom's Avatar
Originally Posted by Kaw1000 View Post
Guys,
in the CVA or the drive pin for the hex?
Old 11-20-2013, 09:21 PM
  #8698
Kaw1000's Avatar
the CVA
Kaw1000 is offline
Old 11-20-2013, 09:23 PM
  #8699
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
according to your setup sheet, your using a 78 pinion with 23 spur
DriveItLikeYSIT is offline
Old 11-20-2013, 11:49 PM
  #8700
AndrewTom's Avatar
the CVA
try putting a small notch where the set screw locks down on the pin. also, a stronger threadlock compound could be used.
also, it is a steel set screw going into a steel part, so you should be able to put a little more torque on it, given that your wrenches are decent.
