TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-05-2012, 02:29 AM
  #856
murky123's Avatar
Originally Posted by Frank Root View Post
It was actually developed on a low grip, loose, outdoor track and worked very well. The kit setup is actually based on our testing there. If the track is larger and higher speed, that sway bars might be an added bonus as well.
thank you.
the reason I asked on what surface this truck was tested, is because the 22 buggy is very hard to drive on low grip surface, when on high bite clay the 22 buggy is very hard to beat, but when on low grip dirt, the 22 buggy has a lack of rear traction. Im hoping the 22SCT does not has that problem.
murky123 is offline
Old 08-05-2012, 02:51 AM
  #857
TLRacing
Mike Mellin's Avatar
Originally Posted by theproffesor View Post
looks like this driver has the sway bars that fit rear. the body on the ground in back ground looks like Chambers
The 22SCT is Ryan Dunford's and that is his body in the background. He is using pre-production sway bars.
Mike Mellin is offline
Old 08-05-2012, 02:59 AM
  #858
ScottKelly911's Avatar
Originally Posted by Panda-PR View Post
What motor are most of you planning on using? I have a mamba 3800kv that I dont use on the scte, will it work? Too much?
Originally Posted by goehm View Post
That's a heck of a motor. It's a 4 pole non-sensored, and while it has a ton of torque, runs cool, and long - I think it's too much for a 2WD SCT. It's really a 4WD motor.
You can always tune it down with your ESC, but probably not the best motor choice.
My friend Rory runs the castle 3800kv/sidewinder in his XXX-sct and even though a lot of people give him a hard time about it, he's still one of the fastest true sportsman drivers at both WCRC and OCRC in Pro2. I do think he has it turned down a bit so it doesn't hit so hard on the bottom and might have the EPA turned down a little. I've driven his truck several times and honestly, that system even in his 2wd is smoother than most non-sensored systems out there. It's still not as smooth as a sensored, but if you're on a budget and already have one, it's not a bad place to start just to get you on the road.
ScottKelly911 is offline
Old 08-05-2012, 07:48 AM
  #859
Trader Rating: 22 (100%+)
Does anybody know the offset of the 22sct wheels? I am thinking about getting this truck, and need to know if my AE +3mm wheels will work. I would hate to buy more tires.
Why didn't they standardise these like 1/8th buggy wheels?
rcmiket is offline
Old 08-05-2012, 08:09 AM
  #860
WIGMAN's Avatar
Trader Rating: 19 (100%+)
Try reading the first post and you would see that they are 0 offset wheels....same as the SCTE.
WIGMAN is offline
Old 08-05-2012, 09:32 AM
  #861
Trader Rating: 36 (100%+)
You could buy an extra set of hex adapters and machine them to a thickness to get you below the 296mm max width. I did this when I switched to xxx-sct from the sc-10 because I liked the look of the Hazzard wheel. I'm not sure about the 22sct wheels, they look pretty good.
It is a RC car, get creative.
thefatkid is offline
Old 08-05-2012, 09:39 AM
  #862
Ok, Wigman, not having an scte makes it a little hard to measure the offset. 0 offset means nothing to me. I need to know the measurement from the rear of the hub face to the back of the wheel bead. What I am asking is if my +3 mm wheels will work on the 22sct to keep it legal, but not too narrow.
rcmiket is offline
Old 08-05-2012, 09:49 AM
  #863
RC*PHREAK's Avatar
Trader Rating: 140 (100%+)
Your +3 wheels will make it too wide. Stock SC10 4x4 wheels will work.
RC*PHREAK is offline
Old 08-05-2012, 10:24 AM
  #864
WIGMAN's Avatar
Your +3 means they have a positive 3mm off set, SCTE wheels have a 0 offset which means they have no offset.
Your wheels will fit but will not be "ROAR" legal and may not fit under your body.
WIGMAN is offline
Old 08-05-2012, 10:28 AM
  #865
goehm's Avatar
Trader Rating: 45 (100%+)
Believe that the Losi guys said was that the truck was designed to be ROAR legal with very little wiggle room to add more width and stay legal (ie: to account for toe, camber and some rear hex tuning options). I think someone asked specifically about the +3mm wheels and found that it would be too wide.
So - based on everything so far - no go for the +3mm.
goehm is offline
Old 08-05-2012, 10:42 AM
  #866
AndrewTom's Avatar
lol, i run 17.5 at my local club race, and i am going to pick another XXX-SCT in a while (waiting for the McGrath & Twitch bodies to be released this month!) i have the sidewinder sct system in my slash 4x4. i never drive it anymore, so i am planning on pulling it out, and putting it into a XXX-SCT to have a basher/modified truck to have along with the 17.5 truck.
AndrewTom is offline
Old 08-05-2012, 10:43 AM
  #867
How thick are the hexes? Maybe I can mill them thinner???
rcmiket is offline
Old 08-05-2012, 12:15 PM
  #868
Trader Rating: 28 (100%+)
Read the rest of the thread the hex thicknesses were already listed
bobf24 is offline
Old 08-05-2012, 12:21 PM
  #869
AlienModified's Avatar
Link? I need a new body for my XXX-SCT anyway!
AlienModified is offline
Old 08-05-2012, 01:33 PM
  #870
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Chambers body is primariy yellow and black, quite a bit different from Ryan's.
Correct, +3mm wheels will be too wide - confirmed.
You cannot in the front at least. The wheel will not have enough clearance and will interefere with the suspension.
Frank Root is offline
