TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 11-16-2013, 10:33 AM
  #8641
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Gmwizard View Post
Anyone have any success conquering severe traction rolling? Indoor clay track with super grip keeps sending the SCT into barrell roles when carrying speed through the sweeper. Running slicks all around right now and im thinking of putting the bar codes back in the front to take away front grip. I already tried roll center, springs, played with camber and camber gain, ride height and all results have me taking my finger off the trigger completely
Thicker swaybars ?
OfnaJoe is offline
Old 11-16-2013, 10:38 AM
  #8642
Casper's Avatar
Trader Rating: 34 (100%+)
Low ride height and limit the doop. Thicker swaybars would help as well.
Casper is offline
Old 11-16-2013, 12:58 PM
  #8643
Gmwizard's Avatar
Ive already went as low as 26mm. Keep going lower? Theres a few huge jumps but i guess i could try. As for sway bars are they allowed in 17.5 blinky? I thought i heard someone say they werent allowed
Gmwizard is offline
Old 11-16-2013, 02:19 PM
  #8644
jk racing's Avatar
Trader Rating: 20 (100%+)
I run 27 ft, 24 rr for ride height...so drop it more run it in the weeds
jk racing is offline
Old 11-16-2013, 03:33 PM
  #8645
Spork's Avatar
Originally Posted by AndrewTom View Post
30/5 with the 2.0 parts is as close to 30/10 older design as you can get, since the 2.0 hubs are only available (at this time) in 0* and 5* variants.
for springs, you should consider picking up Truck Green and Truck Black front spings for the front, most are running Green(softer), Blue(kit), or Black (stiffer).
Looking at set up sheets, alot of guys are running the Buggy Yellow rear spring. or a LF spring of some sort.
the 2 hole pistons are great, either the Associated big bores or the new TLR machined ones will do you fine. I like 1.5x2 front and 1.6x2 rear. I think I have 25wt assoc oil all around, and I run 27.5 in hotter weather.
Are you 1.5 in front and 1.6 in the back because that mimics the 57 and 55 -- i.e., smaller hole piston up front, and larger hole piston in the back shocks?
Our track will be freezing cold very soon. I usually run 27.5 oil in the winter... Ive never tried anything thinner. It looks like one of the posts a couple pages back mentions you can go too thin on the oil, and actually lose traction bc of it.
Spork is offline
Old 11-16-2013, 05:01 PM
  #8646
AndrewTom's Avatar
yes, 1.5 front, and 1.6 rear.
yes, too thin can make the car handle differently.
how freezing cold?
just FYI, associated and Losi oils are a little different in viscosity rating.
you can have tlr oil and assoc oil the same viscosity, but assoc is rated 2.5 weights thicker
iex. TLR 27.5 = Assoc. 25.
I would use losi oil, but my hobbyshop isn't going to buy losi AND associated oil, which is understandable IMO.
AndrewTom is offline
Old 11-16-2013, 07:10 PM
  #8647
drepus's Avatar
I've never heard of sway bars being banned in any off-road class so strap em in!
drepus is offline
Old 11-16-2013, 09:39 PM
  #8648
metalnut's Avatar
Trader Rating: 36 (100%+)
I had a rather difficult time at the track again today. Trying to push the car a bit harder, it just wasn't taking it. The rear end continued to wash out very easily, going into corners as well as coming out of corners on power. After speaking with our local national-trophy-winning guru, I tried some setup changes, one at a time
First, I went up to the stiffest front sway bar, leaving the rear with the thinnest one. I then added the two brass transmission weights back on, as I run a shorty all the way forward. Next, I started to move the rear shocks inward on the shock tower, one hole at a time, eventually moving them all the way in. I then adjusted ride height to 27mm front and 26mm rear.
The net effect of these changes, all combined in the end, was more rear grip. However.. the rear of the car dips over in corners a lot more now (as expected). I'm not sure how I feel about that, it feels... sluggish and slow. In addition, I actually manged to traction roll a few times just by steering left/right/left quickly, I'm assuming when the edges of the tires dug in.
In the end, though my lap times improved, I feel like the car is still difficult to drive. Specifically, I feel like there is a VERY small margin for error. If you're a good driver I'm sure you'd love it, but the second you screw anything up, push too hard, oversteer, etc., the car is unforgiving and the rear still kicks out.
I also made the mistake of driving my friend's 10.2. With a slightly modified kit setup (just some different springs), the car felt amazing. Planted, glued, I could push it and push it and it gave me a large amount of warning before it let go. That's when I realized that I don't trust my 22 in the corners, at all. I mentally cringe every time I take a turn, fearing a wash out. That's not right.
The only other idea I have is to reduce my castor. I'm running the aluminum buggy block (25* I believe) with the 2.0 5* castor blocks. Since our track is smooth clay, I'm thinking of going with the 0* castor, which should, in theory, reduce my steering. I suppose I could also go to black front springs or stand the front shocks up more.
I don't want to jump ship to AE, but... I'm starting to lose faith.
metalnut is offline
Old 11-16-2013, 11:34 PM
  #8649
Trader Rating: 16 (100%+)
I'm guessing your running the right tires for the track. ?
AE are bad fast indoors. lol. I got a xxx-sct to try indoors.
Tommygun1 is offline
Old 11-16-2013, 11:39 PM
  #8650
metalnut's Avatar
Yeah, clay tires all around, Bar Codes in the back and Pressure Points in the front. I used to run Bar Codes up front too, but put on Pressure Points in an effort to smooth out the steering balance.
metalnut is offline
Old 11-17-2013, 04:11 AM
  #8651
Gmwizard's Avatar
My feelings exactly.... Im having the same problem, if i run the truck with bar codes and go in hard it washes out, switch to slicks and the car rolls over like a son of a b. Its like i have to "baby" this thing so i do t ask too much of it. Ive tried pretty much everyones setup from local guys to pros and coming up with same results. Im going to try some extremes next week and put the chassis on the floor but im beginning to get frustrated.
Gmwizard is offline
Old 11-17-2013, 08:16 AM
  #8652
AndrewTom's Avatar
what are you at currently for front kick up and castor?
have you tried a stiffer front spring?
alot of guys are running Blue or Black up front.
also, turning down the steering, or reducing the total steering throw may help as well.
Old 11-17-2013, 09:15 AM
  #8653
haagar's Avatar
Have you tried moving the battery back? That made a big difference for me. Off the top of my head, I am running four foams in front of the shorty and three behind (100% sure on the four in front, but not 100% sure about how many it takes in the back).
For the traction rolling, if you read the "Tune with camber links" thread there is discussion about traction rolling being a result of having too much roll stiffness. The idea being that raising the roll center or using heavier sway bars puts more load on the outside tire and less on the inside. When the outside tires get overloaded the result is a traction roll.
haagar is offline
Old 11-17-2013, 09:24 AM
  #8654
manuelcjr1's Avatar
I know said you tried alot of setups but please give this a try if u can. I have had the most fun and confidence with this setup. Just feels great i can push it hard and just cant break the rear end loose. Does exactly what i want. Very confidence inspiring. A guy at our tried it sold his sc10 and has been getting faster and way more consistent.
Front
Toe -1
Ride height 28mm
Caster 5 degree
Kick 30 degree
Sway bar none
Shock emulsion, 27.5 wt, 2x1.5 piston, blue spring
0 limiters, unscrewed shock end 3 turns
Shock location 2 outsideoutside
Bump steer 0
Camber link 1 i am using 2.0 steering rack
Spindle center, 0 on caster block, 3 mm on camber link 1
manuelcjr1 is offline
Old 11-17-2013, 09:28 AM
  #8655
bprc10T3's Avatar
Trader Rating: 101 (100%+)
Front
Toe -1
Ride height 28mm
Caster 5 degree
Kick 30 degree
Sway bar none
Bump steer 0
What is his setup for the rear?Also what type of track are you racing on?
bprc10T3 is offline
