TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 10-28-2013, 08:14 AM
  #8431
Carranza76's Avatar
Originally Posted by metalnut View Post
Interesting and good to know. Hrm... I admit that I haven't been paying too much attention to the 2.0 steering components since I have the Exotek steering rack. Assuming I want to keep it, could I (should I?) still try the 2.0 front hubs and spindles?
Also, I finally got all the parts for my 2.0 shock rebuild (x-ring and spacer kits), as well as the new shafts. Holy cow are these nice and smooth! Also, after all day of practice NO LEAKING! I'm so happy
You would be ok trying the new parts with Exotek rack. If you have any problems PM me and I can try to help you out with them.
I know they tested it with the new 22 2.0 and had no issues.
Carranza76 is offline
Old 10-28-2013, 11:28 AM
  #8432
sapperc's Avatar
Got a question...All the talk about being able to achieve 0 bump steer with the 2.0 front end parts has caused me to wonder. Has anyone running the Exoteck steering rack noticed a bump steer problem using either the 2.0 front end parts or the original front end parts? If so, what did you do to correct it? Any advice is appreciated. Thanks.
sapperc is offline
Old 10-29-2013, 05:02 PM
  #8433
haagar's Avatar
Default Ride Height
How is everyone measuring their ride height? Dropping or bottoming out the chassis and then releasing?
Anything other than dropping is resulting in a much lower front end for me. Have checked for binding and everything is nice and free.
Thanks!
haagar is offline
Old 10-29-2013, 05:22 PM
  #8434
metalnut's Avatar
Trader Rating: 36 (100%+)
Thanks!
I just drop my horizontally from about a foot and measure carefully after. I do this a few times to make sure I get it right. But I'm also running a 26mm ride height front and back. I think most run it higher.
metalnut is offline
Old 10-29-2013, 05:48 PM
  #8435
Trader Rating: 222 (100%+)
Originally Posted by Casper View Post
No I did not raise the tranny as I was using 2.0 front end parts (from the buggy)
So just to double check when we use the new 2.0 hubs, spindles, caster blocks and steering rack we no longer need to shim the tranny 1mm ? (Rear motor)
Thanks in advance
Manatarms25 is offline
Old 10-29-2013, 05:59 PM
  #8436
Casper's Avatar
Trader Rating: 34 (100%+)
Thanks in advance
I was not running them on my lastest MM setup. Did not feel I needed to do that with that setup.
Casper is offline
Old 10-29-2013, 09:36 PM
  #8437
Bob-Stormer's Avatar
Originally Posted by AndrewTom View Post
well, they are now 299 on amainhobbies.
and they are 239.99 on stormer. poop
Check Stormer on Friday. You're gonna like what you see.
Bob-Stormer is offline
Old 10-30-2013, 03:36 AM
  #8438
tipperjackson's Avatar
Trader Rating: 16 (100%+)
Has anyone posted any good set-ups for medium high bite clay for the 22sct with the 2.0 upgrades? I just ordered up all of the suspension upgrades and would like to have a good base line set-up to start with. I'm currently running MM but thinking about going back to rear motor to get more rear traction. Will I have more steering if I go back to the rear motor with the 2.0 upgrades.
tipperjackson is offline
Old 10-30-2013, 03:53 AM
  #8439
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
Yep Casper does it's a midmotor setup you can visit his site for pdf.
mbtoolmaker35 is offline
Old 10-30-2013, 06:25 AM
  #8440
haagar's Avatar
I just converted my SCT to mid-motor and and was kind of leery about how big of a shock position and spring change I had to make. Independently ended up with all the same shock locations and one step lighter on springs front and back vs Casper's setup, so I guess I wasn't too far off!
haagar is offline
Old 10-30-2013, 06:38 AM
  #8441
I just converted my SCT to mid-motor and and was kind of leery about big of a shock position and spring change I had to make. Independently ended up with all the same shock locations and one step lighter on springs front and back vs Casper's setup, so I guess I wasn't too far off!
Which is understandable Casper setup includes the 38g rear squat block not sure if you havethis!
Old 10-30-2013, 06:55 AM
  #8442
MonsterSummit's Avatar
Trader Rating: 15 (100%+)
Couple of questions. New to 2wd sct. For the front pivot block, do you need to get a new(TLR1065 or 234008) front brace to run the buggy pivot block? Or can you use the one that says 30* that comes with the SCT?
Also, a general tuning question, what is the difference between running 30* of kickup and 0* hubs vs. 25* kickup and 5* hubs? Obviously both have a total of 30* kickup, but does one handle differently than the other?
Thanks for the help
MonsterSummit is offline
Old 10-30-2013, 07:15 AM
  #8443
Thanks for the help
http://www.rctech.net/forum/12674782-post5072.html
Old 10-30-2013, 07:39 AM
  #8444
Thank you! I have been reading through the forum and either overlooked that or didn't get there yet. Do you know about the front brace?
Old 10-30-2013, 07:50 AM
  #8445
haagar's Avatar
Not yet. I just got my 22 2.0 and am building it mid-motor. Want to see how they run to see if I need one or two!
I got the mid-motor shorty battery kit. Fits great and super fast delivery!!!
haagar is offline
