TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-20-2013, 06:21 PM
  #8146
Anyone running a D3.5 in blinky? How much end bell timing? Ball park for gearing? Thanks.
Mototech is offline
Old 09-20-2013, 06:26 PM
  #8147
nitro_mt_racer's Avatar
Trader Rating: 230 (100%+)
We run d3.5 17.5 motors in our trucks geared 29/78, med sized indoor high bite clay.
nitro_mt_racer is offline
Old 09-20-2013, 06:34 PM
  #8148
Thanks. How much end bell timing?
Mototech is offline
Old 09-20-2013, 07:39 PM
  #8149
turned all the way up to the stop
Old 09-20-2013, 08:29 PM
  #8150
metalnut's Avatar
Trader Rating: 36 (100%+)
Hey guys. Looking to get more steering out of my truck. I'm currently running the Frank Root set-up that was posted a while back for low traction tracks. Only differences are no aluminum camber block. I am running the brass shim and aluminum kick up plate. I have 1/2 oz in front of the front tower, the brass tyranny weights, 3/4oz in the back of the battery tray, and my shorty pack is all the way forward. The last time out with this set-up I couldn't get it to turn at all. I'm running it again tomorrow in a series race. Thanks
Assuming you're running the same front tires as the fast guys at your track? If so, to get more steering you could do softer springs up front or harder in the back, or softer sway bar (or none) in the front. You could also try to lay the shocks down more up front, or raise the camber links on the front hub. I would try one at a time though. I'll be corrected if I'm off on any of these suggestions. The 22 usually has a ton of steering.
metalnut is offline
Old 09-20-2013, 08:34 PM
  #8151
metalnut's Avatar
29/75 with timing all the way up? Holy crap, that's tall and low torque to boot. I'm running 25/78 with factory timing with my D3.5, and we have a medium technical indoor clay track. 26 pinion felt too tall for getting out of corners quickly. Then again I'm not that fast, so :-)
metalnut is offline
Old 09-20-2013, 10:05 PM
  #8152
jk racing's Avatar
Trader Rating: 20 (100%+)
I must be way off on my gearing then, Novak Ballistic 17.5, full timing, 25/82
jk racing is offline
Old 09-20-2013, 10:19 PM
  #8153
Yep, all the way up. Obviously track size has a lot to do with it. I said medium but it may be large compared to what you're running on. 125'x90' on my outdoor track and 100'x75' or so on last year's indoor track.
Old 09-20-2013, 10:41 PM
  #8154
metalnut's Avatar
Ah, that would explain it. Our track's website says "5,400 sq. ft. racing surface", so, if I can math, that's WAY smaller than what you guys are racing on.
metalnut is offline
Old 09-20-2013, 10:51 PM
  #8155
Yes it is. Obviously we're giving up that low end grunt up off the corner in exchange for straightaway speed.
Old 09-21-2013, 01:57 AM
  #8156
My first go to moves for increasing steering is the simple slide the battery forward,or sliding the rear hubs all the way back,the hub position can help a lot and is often overlooked
silvercrxsir is offline
Old 09-21-2013, 11:50 AM
  #8157
AndrewTom's Avatar
I am 25/78 with a Schuur Speed. timing at 34* or 35*, blinky. my track is tight though.
AndrewTom is offline
Old 09-21-2013, 11:55 AM
  #8158
AndrewTom's Avatar
everything sounds accurate to me.
if i were him, I would take out that weight of the back.
try adding some camber gain to the front end should help a bit.
also, is the set up he's talking about 25/5 or 30/0?
Old 09-21-2013, 08:41 PM
  #8159
Alqwad's Avatar
Trader Rating: 15 (100%+)
Default 22SCT 2.0
22SCT 2.0
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-image.jpg
Alqwad is offline
Old 09-21-2013, 08:57 PM
  #8160
Suspended
Originally Posted by Alqwad View Post
22SCT 2.0
Good try. NOT!
Docrc is offline
