TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-19-2013, 12:48 AM
  #8131
rc-racer75's Avatar
Trader Rating: 27 (100%+)
Got the 22 2.0 steering rack for my 17.5 truck. Like the ball stud placement, but dirt & dust still going to be a problem for it wearing out I think.
rc-racer75 is offline
Old 09-19-2013, 11:44 AM
  #8132
I just got the new rack also and have a question,I was wondering since the ballstud has been moved,do I need to change the bumpsteer at all,I'm currently at 1mm.with the old style rack and love the way it drives,do I need to make any adjustments to keep it exactly the way it is with the 2.0 rack
silvercrxsir is offline
Old 09-19-2013, 12:34 PM
  #8133
AndrewTom's Avatar
i fi remember correctly, the ballstud position on the 2.0 rack is moved up 2mm, to allow for zero bumpsteer if needed
and with the balls positioned horizontal, I think you can adjust ackermen, I think
i'm not 100% sure, casper or frank should chime in.
how about you get out and test it before you go and say its going to be a problem?
AndrewTom is offline
Old 09-19-2013, 01:02 PM
  #8134
Carranza76's Avatar
He actually said he thinks its going to be a problem, not it is going to be a problem and he has good reason for that as its the same design concept as the original which had problems.
Carranza76 is offline
Old 09-19-2013, 03:15 PM
  #8135
rc-racer75's Avatar
I did test it. It would be fine if I had a nice groomed track to practice on. But when you live 4hours away from your fravorite track 702 rcraceway. You have to make do with your backyard practice track. Its loamy dirt and I can't always use water on it. So dust and debris gets in the rack. I clean it after every run but the damage gets done while driving it.
Old 09-19-2013, 03:18 PM
  #8136
rc-racer75's Avatar
Also I did not change any bump steer I still have it at 1mm. I run the 25 degree kick plate with 5 degree caster blocks. I am running 27.5 in the shocks with green springs from 22t. I am super happy with my handling on my backyard track. ride height is 28mm.
Old 09-19-2013, 04:05 PM
  #8137
Casper's Avatar
Trader Rating: 34 (100%+)
The new system does have adjustable ackerman due to the horizontal ball studs. It was also redesigned to be taller to help with heal toe wobble as well as new plastics. We will just have to see how it all works for all of us on if it last longer or not. It should perform better though.
Casper is offline
Old 09-19-2013, 04:07 PM
  #8138
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up mbtoolmaker35 makes the new 2.0 racks
mbtoolmaker35 has the New 2.0 racks now available, only 37.50.
Contact him well worthh your investment.Click the pic to play video.
XXXDad is offline
Old 09-19-2013, 05:15 PM
  #8139
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Brian L View Post
I have been running the MIP cvd's since April in 17.5. Weigh the same as stock and rebuilding my truck now. The pins have some wear but the axle and coupler are still in perfect shape. I had my pins back out a few times with the stock ones and have been real happy with the MIP's.
Thank you for that feedback. I'm going to grind my pin and also try the shrink tube trick for now, but since my CVDs need replacing anyway, I'll probably try the MIP kit in a few weeks.
metalnut is offline
Old 09-19-2013, 11:39 PM
  #8140
Outtacontrol58's Avatar
Trader Rating: 92 (98%+)
I know this has probably been asked so I do apologize, but "if" and "when" is the 22sct2.0 coming out? Any word?
Outtacontrol58 is offline
Old 09-20-2013, 12:03 AM
  #8141
simpson1550's Avatar
Trader Rating: 55 (100%+)
Question, my 22sct is pulling to the right under power. The shock fluids are good, tires good, tried with a gear and ball diff, steering trim good, bearings good, and it's still doing the same thing. It's driving me crazy!! Has anyone had the same problem??
simpson1550 is offline
Old 09-20-2013, 01:21 AM
  #8142
ScottKelly911's Avatar
Check the pins that connect your axles to the cvd's. Mine had pulled out slightly and was causing me to spin out when I turned. When I looked at them, they had worn away some of the aluminum from the rear hub.
ScottKelly911 is offline
Old 09-20-2013, 01:33 AM
  #8143
metalnut's Avatar
If you look back a page or two, we've just had this discussion
metalnut is offline
Old 09-20-2013, 05:24 PM
  #8144
AndrewTom's Avatar
as said earlier, check your CVD's.
also, give all your bearings a good test. maybe use the bearing baster from RPM.
I lost mine, need to find that thing!
Old 09-20-2013, 06:18 PM
  #8145
Hey guys. Looking to get more steering out of my truck. I'm currently running the Frank Root set-up that was posted a while back for low traction tracks. Only differences are no aluminum camber block. I am running the brass shim and aluminum kick up plate. I have 1/2 oz in front of the front tower, the brass tyranny weights, 3/4oz in the back of the battery tray, and my shorty pack is all the way forward. The last time out with this set-up I couldn't get it to turn at all. I'm running it again tomorrow in a series race. Thanks
Mototech is offline
