TLR 22SCT Thread (Check First Page for FAQ & INFO)
#8058
#8059
Part #231013 for the new slider. I believe it shows it will not be in stock till around the 20th.
I am going to try some of the new 2.0 front end parts. I was told they will not make as much of a difference as the buggy cause of the offset of the wheel on the SC.
The set-up sheet I have for J.R. at Newred has 30/0 on it.
#8060
#8061
www.casper-rc.com
Say good by to thrust bearing issues.
Maybe you should explain that these aren't just someone else's thrust bearings and washers - they are dimensionally different.
Caspers thrust washers support the thrust bearing by a factor of 10x in terms of contact surface for the bearing itself. Thrust bearings take an immense amount of load. This system eliminates the issue many are having.
And they are cheap...
#8062
Casper.
Ceramic balls are very smooth and this gives a great diff feel right away as well as they are very hard and have great surface finish and with the improved wear of the grooved washers this thrust bearing has shown to last many diff rebuilds. Now the reason you need to service the diff is the main rings wear out and causing the cruchy feeling. Being the thrust bearing typically was the first part to go this now increases the time between diff builds meaning less maintance and now that the thrust bearing is reusable it reduces the overall cost of diff maintaince. Win/Win!
#8063
www.casper-rc.com
#8064
AND... Casper's thrust bearing is really good and it lasts and lasts. I've been running mine for months. No wear and tear that I can discern and have rebuilt it several times.
#8065
To be clear - the outdrives are only new to the 22 and 22T. The 22SCT included the updated "2nd Op" outdrives. The only new part in the 22 2.0 diff that wasn't in the 22SCT box is the hardened thrust washers.
#8067
www.casper-rc.com
#8068
Yes it it, I think Capser has mad a change in the rear going to 3MM washer instead of 2 MM and he has changed the shock oil also but that should be track dependent. I use a thicker oil cause I race outside in the heat.
Its a great set up and don't be afraid to use it and make changes for yourself.
#8069
#8070
hey casper or frank r.
are these new ticn shock shafts for the 22sct?
TLR233004
http://www.tlracing.com/Products/Def...odID=TLR233004
TLR233001
http://www.tlracing.com/Products/Def...odID=TLR233001
TLR233004
TLR233001
