TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-04-2013, 01:31 PM
  #7846
jk racing's Avatar
Trader Rating: 20 (100%+)
I'm going to sort out the truck in blinky stock first, then come join you in Pro 2.
jk racing is offline
Old 08-04-2013, 05:00 PM
  #7847
sapperc's Avatar
Here's a little tip for those of you who like me are really bugged about the short TLR front springs bouncing around when the shocks are at full extentionl. The bottom shock retainer cups for the Pro-line Powerstroke shocks are just larger enough around that the TLR springs fit snugly onto them. And they fit nicely onto the TLR shock ends. No more springs bouncing around.
It's probably not worth buying the Powerstroke shock rebuild kit just for a little piece of mind. But if you have a kit laying around already, give it a try.
Problem solved.
sapperc is offline
Old 08-05-2013, 06:10 AM
  #7848
dirt42fan's Avatar
Trader Rating: 150 (100%+)
Originally Posted by Casper View Post
We used some of these. They are a little thicker then that 22 battery foams and they are a little wider so they don't fall out of the car either.
http://www.horizonhobby.com/products...t-spt-LOSA4015
Ok thanks Casper. And just to be sure that was with a normal sized battery correct?
dirt42fan is offline
Old 08-05-2013, 01:28 PM
  #7849
AndrewTom's Avatar
full size i think.
AndrewTom is offline
Old 08-05-2013, 01:47 PM
  #7850
Casper's Avatar
Trader Rating: 34 (100%+)
Yes we use a Venom 5000mah 60C battery.
http://www.venom-group.com/60C-2S-50...-ROAR-UNI.html
Casper is offline
Old 08-06-2013, 05:38 PM
  #7851
AndrewTom's Avatar
just picked up an AVID bearring kit, battery tray, and Red Triad pads and a 78 spur for my 22SCT.
I'll let you guys know how the battery tray fits and functions.
Old 08-06-2013, 05:43 PM
  #7852
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up avid IS d-bOMB
Post some pic.... Avid makes great RC products!
XXXDad is offline
Old 08-06-2013, 07:01 PM
  #7853
The Avid tray is very nice, looks and works fantastic. Heres a pic of it in my truck
solly is offline
Old 08-06-2013, 07:58 PM
  #7854
AndrewTom's Avatar
^ that about sums it up.
its about 3 or 4mm lower in height from chassis then the stock one. this is great!, so you can snug the tray up to the battery, and still be able to remove the battery by simply undoing the straps.
no more finessing the battery out, LOL.
it adds weight, and its about as low as you can get. on the chassis, and up front.
so far, its $16 well spent. very well spent, no more foam to lose in front of the battery.
now I need to buy one for my 22T!
after talking to my local hobby shop owner, I can honestly say that Avid is one of my favorite companies.
they listen, they provide, they innovate. AVID For The Win!
Old 08-07-2013, 07:40 PM
  #7855
AndrewTom's Avatar
quick question for casper,
would there be any reason that you can't/shouldn't run -1* rear camber,
or is it best to stick with -2*?
ran basically the casper/dunford setup all last weekend, truck worked really well, needs a few tweeks.
Old 08-07-2013, 08:24 PM
  #7856
Casper's Avatar
No reason you should not. Less camber should result in a little better forward bite and a little less side bite.
Casper is offline
Old 08-09-2013, 01:51 AM
  #7857
ScottKelly911's Avatar
Just wanted to post pix that I'll be putting up on the front page of some parts mbtoolmaker35 made in addition to his steering rack. Very nice quality! Parts are available at http://www.casper-rc.com/upgrade_parts.htm
1mm Brass Shim to raise transmission
14gram transmission weight
ScottKelly911 is offline
  #7858
Brass 14 gram transmission weight
Old 08-09-2013, 02:05 AM
  #7859
mbtoolmaker35's Avatar
Trader Rating: 77 (100%+)
Thumbs up thanks
Thanks scott for all your hard work keeping the best thread going!
mbtoolmaker35 is offline
Old 08-09-2013, 02:11 AM
  #7860
You're welcome! Glad it's been helpful to people. The real hard work comes from people like yourself who's actually making stuff, so thank you as well!
Now that the 22 2.0 has been announced, the ST and SCT can't be far away. Anyone else here going to try out some of the new parts on their 22sct once they're available? I'm thinking the new front end suspension parts will make it onto my truck as well as the new shock shafts, shock plastic parts and x-rings.
