TLR 22SCT Thread (Check First Page for FAQ & INFO)
#7531
Hey Casper I'm running your setup minus the rear sway bar. I race at king hobbies (king headz) in valparaiso IN. I'm running 17.5 blinky w a 78/25 d3.5. I had a 26 tooth pinion on but I dropped it to 25. I'm having a bit of trouble w a double single just not able to consistently clear it. I'm running a full pack do you think a shorty may help? I'm not sure if the less weight will help w a 17.5 class
#7532
A shorty pack definitely makes the truck feel more nimble and should fly a little better. I ran mine about midway forward.
What is the traction like at the track? What tires are you using? What are the guys who can clear the jump using? How does their line compare to yours?
Sometimes there's jumps you can't clear. Better to be safe than case it and turtle.
#7533
Don't think I would rate a steering servo by motor type / size. The size and weight of the RC, track conditions, BEC voltage, and driver skill and preferences are important in selecting a servo. Really it comes down to how much torque the servo has, how fast the servo is, and how well it really performs. In other words, is it glitch and sputter-free, does it operate smoothly, and does it really perform at its rated torque and speed.
The servo in question is the Losi LOS0812. It sells for about $43.00 US. In my mind, this is a budget stock servo. It compares well to other servos in this price range. Here are the specs:
Specifications:
Size Category: Standard
Type: Digital
Torque: 140 oz-in @ 6.0V
Speed: .18 sec/60 degrees @ 6.0V
Bushing Or Bearing: Bearing
Gear Type: Metal
While there are a lot of opinions about servos, in the end only you can decide what's right for you. Hope this helps. Good luck.
#7534
Shorty pack will make the truck fly farther. You should be able to take 2 stock battery pads and put one in front and one behind laying down. That should make the pack centered of where your full one was. I would try it there and you can move it around.
I think the shorty should be run due to weight for 17.5. The only time I would think about a full is if track was slick and needed some more weight. Don't forget to reset your ride height and camber once you put the shorty in.
#7535
@ _44...the RTC esc is only rated down to 13.5 turn
#7536
#7537
Thanks guys I might just build up a kit for him...
cheers Toddy
cheers Toddy
#7538
Hi,
Anybody got a good starting point setup for mid-motor astro?
Cheers
Cheers
#7539
[email protected] (Jon Gagnon) Mid-Motor setup he used to win the Battle On The Green race on Astroturf, 3/17/13. Congratulations Jon!
*Front Toe is .5 not 3*
http://pages.videotron.ca/jaunerc/22SCT_BotG.pdf
#7540
Here ya go. For future reference, it's also on the first page under RCT Member setups
#7541
Thanks guys they run 1/8 scales so track is loamy loose traction is never too plentiful. I run city block 2 wide and carvers up front.
#7542
remember, you can run Boosted with the RTC's stock ESC, you just need to change to a lower gear ratio, and change profiles on the ESC.
will your track allow for 17.5 boosted to run with 10.5 blinky?
#7543
With the d3.5 17.5 Maxzilla I ran at least a 28T pinion - 28/78. Casper setup exactly.
#7544
The only trick at our track is tires. It's a hard packed clay track (wet in the mornings), that gets pretty damn dusty over the day. The Panther Rattlers work great when the track is swept, but when it's dusty, my rear end gets pretty loose. I tried some Panther Raptors in those dusty conditions (all four tires), but they didn't really have much side grip at all. So, I'm a little stumped as what I should do.
#7545
Hi Nicolas, you're welcome, I don't know if anyone has. I know that was used by Jon Gagnon with a 17.5, but he'd have a good idea if he thinks any changes would/should be done if running mod. But my guess is it would be the same with the exception of maybe a couple minor things like gearing and maybe going up 2.5 in shock oil or something if there's big jumps. Hopefully Jon chimes in and gives some input. But I'd start from there for a baseline starting point.
