TLR 22SCT Thread (Check First Page for FAQ & INFO)
#7471
Losi just needs to come off it and make a more flexible molded chassis. thats the REAL problem. this truck has EU written all over it which means its not suitable for an "average" dusty US track. not everyone who buys this truck has the luxuary of indoor clay, carpet/turf, or even sugared surfaces to race on. the sc10.2 just eats this truck in the "real" world.
#7472
Yes mr larson i have two...one is my close friend who is a truck driver, the other is mine which i traded my desc210 for. i know it all depends on driver,setup and all of that but i really feel this truck needs to shed the metal chassis and go with something else. ive owned/raced over 8 different platforms and this by far needs the most help in looser conditions IMO....i even had a venom gambler in mid conf that was more hooked up than this. my homemade sct would turn better consistant laps. im no newbie and im a pretty good driver and i stand by what i posted (no flame) intended but these CAD cars dnt cut it. remember the hpi rs4 pro3? long story short...make an EA3 chassis for this thing and watch it become a contender....Everywhere! but until then i doubt this truck will win a major race race against AEs ryans anytime soon
#7473
Try both. A stiffer front spring and stiff front swaybar and see what you like. I may be to go to a less aggressive front tire like a switch. Dusty conditions can be hard. Your rear end may be too soft with the white rear springs and the rear end my be dumping on exit. Try all these things.
I would try moving the battery back 1 pad.
maybe move the top of the rear shocks in one.
if you have caspers setup, do you have 2mm on the hub or 3mm?
maybe a Tazer or a Hole Shot would work a little better on the rear? or are the rattlers the hot ticket?
my track can be get a little dusty, I have always had good luck running hole shots and/or blockades. heck, I have run enduros and they work well.
I'll play with all these options.
#7474
Ok, I will play with stiffening up the front a bit. Can you quickly explain what you mean by the rear dumping on exit due to too-soft springs? I thought softer springs usually gave you more grip, no? A big part of it is the tire choice, I realize. Perhaps I have to put my OCD to rest and try different tires front than back.
#7475
Is there a way to use traxxas slash 4x4 rims on a losi 22 sct and keep the same off set?
#7476
Anyone running a Tekin Gen2 7.5. Looking for some initial setups for Tekin RS esc. Sensored or Dual. I am running the Avid slipper 84 spur, and will be putting in the aluminum idler, and ordering the red pads.
Currently running a LRP x20 8.5. I do know the Gen2 has a significantly higher KV rating
#7477
#7479
#7481
Not really. The other wheels are pretty offset and there is not a hub or a hex that will compensate for that significant offset change.
#7482
I havent tried because I haven't had the need since I run an SCTE, but you may be able to get the rears offset within the useable range of the slash 4x4 wheels by trying Losi SCTE hexes in the rear as they are MUCH thinner than the 22sct hexes. I dont think it'll be possible with the fronts as they're only about half the width of the standard 22sct front hexes. So you'll still probably be a little wide. Maybe close tho. Or you may be able to run the 22sct standard front hexes in the rear and scte hexes up front (slight wheel well modification may be needed) to bring them closer to the same width. Worth trying if u have access to a friend's scte hexes to see if they'll fit.
#7483
Ok thanks for the help guys
#7484
just got a 2wd what settings would you run on a tekin Gen2 and 17.5 my track allows timing and boost.
