TLR 22SCT Thread (Check First Page for FAQ & INFO)
#7427
Check out http://www.tqrcracing.com
They carry Top, Spec-R, etc., all of whom make very nice parts for a lot of popular brands. You can definitely find a lot of different washers, and shipping is FAST.
#7428
#7430
Yeah no one cuts those out anymore and they are not cut out in the "with holes" body either. That area spits way too easy. Maybe for a big event in high wind but then I would probably only cut out the inner half so you don't have that thin section you are talking about but in general if I have to cut out the holes I am leaving in the rear most deck squares in place and leave the rear fenders uncut as well.
#7431
Hi all new to the board. I pick a 22SCT RTC up for my son back in May. He is 8 and tearing up the track in sportman class. I am not new to the hobby, but it has been 20 years or so. I just picked up a TEN-SCTE 2.0 so not to compete with my son. This board has been very informative. I have already made mods to the 22sct rtc that has made improvement to my sons driving and run ability on the home club track. Great thread.
#7433
How tight are the tranny screws too tight will cause binding
#7438
I had all kinds of trouble with transmission binding. In the end, it turned out to be a bad layshaft bearing (the one on the half of the case that comes off). It seemed fine, but once the shaft was putting pressure on it, it would bind up. But.. my layshaft was also a little bent, and tightening the transmission case screws too much would bind it even more. So, several components were at play. I would take it one step at a time, start with fresh bearings, make sure the shaft isn't bent, and then carefully tighten the case, checking for binding every quarter turn.
