TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 04-23-2013, 12:11 PM
  #6961
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Originally Posted by lewi007 View Post
I have a gear diff I use in a pinch when my ball diff decides to poop out & I use the high pressure grease that comes w/ the ball diff rebuild kit as the lubricant because the gear diff leaks. I know I read somwhere here why oil is used and thought it had something to do with more friction (increasing)making the rear end more stable. I really can't tell the difference.
ok good to know, thanks.
Originally Posted by Casper View Post
Black grease works well but I find it breaks down faster. Also with Silicone oil you can tune the diff a little.
Casper, do you know if this is a common problem with the gear diff and if theres a way around it? Also would you happen to know the part number to the gasget for the diff?
mysupratoy94 is offline
Old 04-23-2013, 12:21 PM
  #6962
Casper's Avatar
Trader Rating: 34 (100%+)
I have not used the 22 gear diff so I really don't have a lot of info on it. Looks like the gasket only comes with the case.
http://www.losi.com/Products/Feature...rodId=LOSA2953
Casper is offline
Old 04-23-2013, 12:50 PM
  #6963
I may be way off here so someone with knowledge please pipe in but couldn't you use 'gasket maker'? Most automotive stores will carry it. I think it's either blue or black in color (permatex).
lewi007 is offline
Old 04-23-2013, 01:38 PM
  #6964
Casper's Avatar
Yes if the issues is with the gasket and not the outdrive o-rings. Getting the diff apart would probably be difficult if you went that route as well. But technically that would be a solution.
Casper is offline
Old 04-23-2013, 01:59 PM
  #6965
you could tell me that my idea just plain sucked. I would be okay with that.
lewi007 is offline
Old 04-23-2013, 02:12 PM
  #6966
Casper's Avatar
It doesn't suck if you don't mind getting it apart. Gary Katz did this with the XXX gear diff. Worked great.
Casper is offline
Old 04-23-2013, 02:15 PM
  #6967
WIGMAN's Avatar
Trader Rating: 19 (100%+)
Casper do you happen to know what weight diff fluid comes in the 22 gear diff, I just bought one and was expecting grease when I took apart, much to my surprise there was fluid in it.
WIGMAN is offline
Old 04-23-2013, 02:59 PM
  #6968
Casper's Avatar
Nope I don't. I would guess it is around 5K though.
Casper is offline
Old 04-23-2013, 03:31 PM
  #6969
WIGMAN's Avatar
Kinda what I figured Casper but thought you may know for sure.
Originally Posted by ScottKelly911 View Post
Hey Wigman, thanks for the update. Sounds like a very fast setup, be interested to see how you do with a little more wheel time and if you make slight changes to tame down the twitchyness. But at the same time, a truck on edge can be REALLY fast when driven well. Congrats on the great runs, bummer about the hack jobs though but glad it was a good positive experiment that showed promise. How was the truck when rotating turns? Easy to rotate in a controled manner or did it rotate more like a snap turn?
Scott , It was on the edge and very fast, got the traxxas turnbuckles on order for the weekend so that will not be an issue anymore. it was fairly easy to get through the turns, there was one 180 degree corner that it snapped on every now and then, As I mentioned we were racing on ozite carpet and that corner was on some of the old....really old stuff that had less grip. I am very interested to see how this truck runs on dirt or clay with my mid motor the way it is. we still have way too much snow on the ground to thin about that though.......LOL my track beside my garage has about a foot of snow on it here and there, what doesn't have snow has lots of water, hope to out in the dirt with this bad boy soon.
WIGMAN is offline
Old 04-23-2013, 03:33 PM
  #6970
spider882009's Avatar
Trader Rating: 7 (89%+)
Cool Wow!!!
I have 2 of them and both have black grease in them both! Weird!!! I feel bad w/ outdoor starting my 22SCT has become a shelf king along side my 22 as queen cause no outdoor track around here runs much 2WD let alone 17.5.
Ive raced my Ten-SCTE 6 times in the last 14 days. LOL
spider882009 is offline
Old 04-23-2013, 04:47 PM
  #6971
If its leaking from the case i will give this a shot, nothing to loose by trying. Hopefully its just leaking from the outdrives which may just be worn orings
Old 04-23-2013, 09:29 PM
  #6972
AndrewTom's Avatar
it comes with like 1,000... and not much of it on that part. ran one in my 22T for a few races, worked great, didn't leak with 3,000 in it.
AndrewTom is offline
Old 04-24-2013, 05:17 PM
  #6973
Carranza76's Avatar
New Steering for all 22 series cars now out:
http://www.exotekracing.com/tlr-22-s...-22-22sct-22t/
Scott Kelly would you add to front page?
Carranza76 is offline
Old 04-24-2013, 05:58 PM
  #6974
AndrewTom's Avatar
i am fathomed; how are those bits of aluminum worth $70.00? thats like 25% of a 22T or 22 buggy???
and what good does it do? how does this improve the vehicle?
IMO there is nothing wrong with the current slider design.
Old 04-24-2013, 08:45 PM
  #6975
Carranza76's Avatar
Not having to replace the housing every few months and better steering but in all honesty I bought this for my buggy only my sct steers awesome but my buggy could use a little more.
