TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 04-11-2013, 09:29 PM
  #6871
AndrewTom's Avatar
Originally Posted by lewi007 View Post
ANyone have any advice on a different wheel other than the TLR7011? Two straight weeks I stripped a wheel. I do run the .75 wheel hexes so I know I am losing some 'meat & potatoes' compared to the stock hexes. After stripping the first one I always ensure my nutz are tight (can I say that?) so I am curious if a more robust wheel exists? Thanks.
P.S. Casper/Dun clay setup was run for the first time tonight and my lap times are more consistent, Haven't best my fast time yet but I'm still learning to drive the setup, thanks!
i cannot imagine stripping the wheel hexes. are you using the serrated locknuts??? if the lock nut backs off, then it could allow the wheel to whobble on the hex.
AndrewTom is offline
Old 04-11-2013, 09:42 PM
  #6872
Dirtryder219's Avatar
Trader Rating: 58 (100%+)
+1
You can also add a drop of Loctite to the threads before applying the nut. I personally do this on all my 22 cars and I don't use serrated locknuts. Never stripped a wheel or had on come off either. We run the TLR wheels and the JConcepts wheels.
Dirtryder219 is offline
Old 04-11-2013, 09:46 PM
  #6873
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by metalnut View Post
Ok, one more question
I've torn down the used 22SCT I bought and am now putting it back together. It looks like some of the wheel bearings may need replacing. I don't know if these are the ones that came with the kit originally, but most are the brown-rubber-sealed Losi heavy duty looking ones. So, if I do in fact have to replace them, would you guys go with the same HD ones? I ask since Fast Eddy has a whole kit: http://www.fasteddybearings.com/team...d-bearing-kit/
Thoughts?
I do recommend the HD bearings for the rear hubs. Those get a lot of abuse and the HD ones do hold up better then most std bearings.
Consistency normally wins over a fast lap. Granted consistent fast laps usually beats slow consistent laps! LOL
My point is I usually don't worry too much about a single fast lap as I do in being able to consistently run competitive laps for a whole race.
Casper is offline
Old 04-11-2013, 11:33 PM
  #6874
ScottKelly911's Avatar
Were you using the dish inserts on your wheels? The only time I have had any problems like that was when I was running the dish inserts. When using the dish inserts with serrated lock nuts, the dish will slip and eventually back off the wheel. I've lost wheels off the truck that way before and the final straw for me was when the nut backed out and as AndrewTom described, the wheel got loose and stripped the hex. I've since stopped using the stock wheel dishes and use the wheel rings instead of the dishes and have also used the JConcepts Hazzard wheel with their Hazzard Dish inserts. The way the JC inserts work is that they have a male section that sits in the female cut out so the dish cant and wont slip. I wish the TLR dishes would have just used the same screw holes that the faux beadlock rings use. But to answer your question, any wheel with an SCTE offset will fit the 22SCT. For a list of the wheels, check the front page.
ScottKelly911 is offline
Old 04-12-2013, 01:40 AM
  #6875
metalnut's Avatar
Trader Rating: 36 (100%+)
Well, crap. I finally tore into the transmission and just realized that the roller I got has an Avid Mod slipper in it. I want to run 17.5 and I had the Losi 78T spur. Problem is, the guy didn't send me the original slipper parts. So it doesn't look like I'll be going to the track this weekend. *sigh*
Maybe I shouldn't buy used.
metalnut is offline
  #6876
metalnut's Avatar
Oops, double post, sorry.
metalnut is offline
Old 04-12-2013, 06:23 AM
  #6877
Grandturk's Avatar
A - don't buy used unless its almost free.
B - what size spur is on it? You can just go with a bigger pinion.
Grandturk is offline
Old 04-12-2013, 06:36 AM
  #6878
Oh yeah Fo Sho, Just looking for 'The wow factor'. See the other racers start to sweat. It's on baby!
lewi007 is offline
Old 04-12-2013, 06:45 AM
  #6879
yeah, I took the dish inserts off after the first stripped wheel as I knew I would gain a 16th or so of more thread. Loctite was suggested by AndrewTom, I guess I could try that but as many times as I take the wheels off I can't se it drying intime for the next race, heat, main etc. I'll try Serrated nuts if they aren't already and see how that goes. I could hear the 'grind' on the course before a jump, thought it was the ball diff, when that was still butter I knew it had happened again.
lewi007 is offline
Old 04-12-2013, 07:41 AM
  #6880
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Metalnut, I feel your pain the exact same thing happened to me.
Just go down and see Scott at TRCR and get either the ae slipper setup or the losi. He will defiantly have the ae stuff.
I should be down there sat for some SC racing if you need any help look for me.
Kenny
kjohnsiii is offline
Old 04-12-2013, 08:58 AM
  #6881
Casper's Avatar
The thing about repeated therad lock is after a few applications 3-5 it starts to collect on the threads and works without neededing to apply more for a little while. It is worth a try. I use serrated nuts and crank the nuts down if I use disks. The other trick is the glue the disks to the wheels.
Casper is offline
Old 04-12-2013, 09:57 AM
  #6882
metalnut's Avatar
I usually don't buy used, but this being my first dirt RC racer of any kind, I wanted to play it smart. To be fair, the truck did come with lots of TLR aluminum upgrades, carbon fiber shock towers, 3 sets of wheels and is otherwise in good shape. But yeah, I'm missing a couple of screws and some of the stock parts.
It's the 87T spur. I don't actually have any pinions for a good FDR with that, but I'd also rather stick with the Losi slipper.
Kenny
That's actually where I was going to go Sunday, my first time, but since I need a couple other parts I just placed an AMain order. Looks like I'll be going down there next week or next Sunday. So it goes sometimes
metalnut is offline
Old 04-12-2013, 11:08 AM
  #6883
Trader Rating: 24 (100%+)
My front left wheel is locked up and wont turn. It's not the bearings as far as I can tell. With the wheel off it spins pretty free but feels kind of gritty. It spins ok until I tighten the wheel nut down all the way. Any ideas?
chevmaro is offline
Old 04-12-2013, 11:13 AM
  #6884
Grandturk's Avatar
If you are using the plastic wheel hexes, you can't crank down on the wheel nuts. Snug them up, but don't crank hard on them.
Upgrade to aluminum hexes.
Old 04-12-2013, 11:36 AM
  #6885
make sure the spacer is between the bearings, dont ask how i know that...
gen3busonoma is offline
