TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 03-28-2013, 10:16 AM
  #6676
Originally Posted by Casper View Post
Do you have a track with experiened racers near you? Honestly there is so much feel in building a ball diff it is a huge help to have someone walk you through the build and setting process to see how tight they initially set there ball diff prior to setting the slipper and how to check it after the first few runs to make sure you can get the ball diff setup properly so it survives break in and if you can get it broken in properly and get the slipper set properly it should last you a while but with all that said your SCT will be probably the hardest car on a ball diff due to the weight and size of the tires of any 2wd RC.
Thanks for the reply back Casper. There are experienced racers, and they all have said switch to gear diff. LOL! I did however get a lesson on slipper clutch setting. Very informative and dooley noted. I won't forget. I got my slipper set correctly and then measured the bolt distance that was portruding past the slipper nut so at least I have a starting point. But this was after I barked my gear diff. so we'll see how long it lasts! I suppose my issue was not tightening the ball diff. down enough, barking it & in the process glazing my pads while setting my slipper. Before I had the slipper lesson I tempd my motor and it was hotter than ever before, 160, yikes (19 pinion, 84 spur. 6.5 turn) normally around 120 degrees. Lesson learned, slipper is very important, learn to do it or have Mark from GofastRacing (Batavia Ohio) set it for me. I prefer to learn to do it myself, hate bothering folks if I don't have to, they want to race too! What I have found is that it is extremely hard to listen to your motor/diff and slipper on the track when everone is racing. Hearing is pramount but it's all about the feel. I just haven't honed in my super jedi rc feeling powers yet.
lewi007 is offline
Old 03-28-2013, 10:18 AM
  #6677
ScottKelly911's Avatar
Originally Posted by kjohnsiii View Post
Nice write up Scott!
Thanks!
Originally Posted by Brian L View Post
Aluminum idler gear coming from TLR. 332009
Wow, good to see! I stripped an idler on Sunday, it's only the 2nd one I've stripped since I put the truck together, but it's nice to not have to worry!
ScottKelly911 is offline
Old 03-28-2013, 10:32 AM
  #6678
For those of you looking to get this, it works great, just keep in mind, you will want to put some grease seeing as you will now have a metal to metal gear contact. Some good lithium grease or I have even use green lube in a bind with good success.
hacker07 is offline
Old 03-28-2013, 02:44 PM
  #6679
weavty1's Avatar
Thumbs up
That's crazy this is just now surfacing.. I read about this same idler gear, sometime back in early Feb this year, with the same part number and everything..
I think you guys might have a mole inside, Ryan!!
weavty1 is offline
Old 03-29-2013, 11:48 AM
  #6680
gticlay's Avatar
Trader Rating: 14 (100%+)
Same thing here - one of the fastest racers at our track uses a gear diff in his stadium truck and his short course truck. Even beats team guys with them...
gticlay is offline
Old 03-29-2013, 12:52 PM
  #6681
Casper's Avatar
Trader Rating: 34 (100%+)
We have been testing this for some time.
Casper is offline
Old 03-29-2013, 01:19 PM
  #6682
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Just image how fast he'd be with a ball diff
Frank Root is offline
Old 03-29-2013, 03:33 PM
  #6683
gticlay's Avatar
And a hydra-drive
gticlay is offline
  #6684
WIGMAN's Avatar
Trader Rating: 19 (100%+)
I must say Frank these 22 diffs are difficult.......I have been racing for 20 years, I could build a xxx series diff in my sleep and make them last for a very long time, these 22 diffs have be baffled to the point I am thinking of throwing the gear diff in and being done with it, I have watched the tlr video dozens of times, I have even(i hate to say this) tried the associated diff screw thrust bearing and spring. That did make it a little better but man it gets frustrating when your diff goes out after only a couple race days. I dont even run mean motors, 13.5 blinky in 22b, 22t and 22sct, the 22b diff is holding fairly well but the other two .......sheesh.
WIGMAN is offline
Old 03-29-2013, 03:35 PM
  #6685
WIGMAN's Avatar
And a hydra-drive
The track I race at in the summer was so bumpy and rutted out I actually thought about putting a hydra drive on my 22sct. My buddy still has a couple, if we could have found a decent gear i would have given it a shot......LOL
WIGMAN is offline
Old 03-29-2013, 08:17 PM
  #6686
R/C Tech Elite Member
LBR_Frank's Avatar
Anyone know if the AE 30wt oil is the same viscosity as the TLR 30wt oil?
LBR_Frank is offline
Old 03-29-2013, 08:28 PM
  #6687
AndrewTom's Avatar
Assoc 25wt shock oil = 27.5 TLR/Losi oil.
so, 30wt assoc. will equal 32.5 TLR oil.
thats what I have been told.
AndrewTom is offline
Old 03-29-2013, 08:31 PM
  #6688
LBR_Frank's Avatar
10-4, thanks for the help.
Old 03-29-2013, 09:29 PM
  #6689
AndrewTom's Avatar
no prob.
sucks that its like this. of course I learned about the difference a week after i went out and bought all the associated oils. oh well.
associated's oil is made by Lucas oil, so it should be good.
Old 03-29-2013, 09:35 PM
  #6690
LBR_Frank's Avatar
no prob.
Agreed, was wondering why my 30wt shocks felt stiff... now I know why lol. was using TLR 32.5 equivalent.
