TLR 22SCT Thread (Check First Page for FAQ & INFO)
#6601
Honestly guys give Casper's and Dunfords latest setup a go on ANY track surface aside from full on blue groove. I ran this both on a local low to mid level grip to a full on smoothy indoor clay track and changed only ride height and rear shock angle. It's a good "standard" setup that I feel with a few minor tweaks can work nearly anywhere.
#6602
Has anyone else had an issue with the driveshaft pins working their way out? I've got a nice groove carved out of my rear hub from the pin sticking out. I built it with blue loc-tite and it stayed in there for several months without a problem. Got a friend running a 22 SCT with the same issue, he's gone through 3 or 4 pins the last few weeks. Any suggestions to keep it in there?
#6603
#6604
my local track is not completely blue groove, on race days in the morning we sweep the track, but as we run on it, it gets more and more blue groove.
whats best for ~blue groove? 2 hole or 4 hole pistons?
my truck is mainly kit set up, running blinky 17.5. The only things i've done is switch to Green front, 3* blocks, move the rear hubs forward, 2 hole pistons, and switched to Buggy Yellow rear springs. and sway bars White/White currently. i have 27.5 in it now, may go up to 30 rear
my truck handles really well, just looking for a little advice/input for ~blue groove
should i try out 25*/5*?
#6605
#6606
my ride heght is currently around 29ish. Losi Ride height gauge) I cannot remember if i set it at 28 or 29 at the track. I am planning on getting to the track during next week, spring break for me to practice.
I am thinking about going to 25*/5* set up, see where that gets me.
-1 camber front and rear.
#6607
My local track tends to go from med to high bite by the mains. Im running a modified Casper/dunford setup.
My Changes for higher grip.
Shock ends unscrewed 1.5 front
shock ends flush rear
Yellow front sway bar
hubs middle
truck is good bullt still a little "rollie" when bite is up. Next outing going to try AE Blue up front and AE white or gray in the rear to stiffen up a little.
roc
hubs middle
roc
#6608
hubs middle
roc
hubs middle
roc
should I take them out?
#6609
I'd like to get a little more corner speed. track is tight. I can keep up with most of the guys, but it looks like I mainly need more practice, we just changed the track a little (moved the pipes around, flows a little better now.)
If you post up the rest of your setup we can help more and be more detailed about suggested changes.
#6611
front
toe 0*
ride height 28mm body off
camber -1*
3* castor currently, 30* kick
white sway bar. 27.5, 2x1.5mm pistons, truck green, limiters 1mm
1-outside 0mm bumpsteer
Camber link is #1, 2mm under inner ballstud, 0mm outside.
Rear motor, ball diff. 3* toe LRC, -1* camber 2* antisquat
28mm body off. hubs 1mm front. standard width hex. white sway, 27.5-may go to 30. 2x 1.6mm. buggy yellow spring. 1mm limiters
Camber link 1B, 0mm inside, 1mm outside
shock location 2-outside
battery spacing-3 pads back. 7g on top of trans.
tires vary, I really like blockades when its a little loose, but holeshots work really well when it blues up.
i have ran enduros, but they seem to push more. they feel like they have a firmer foam insert then the blockades.
i run Soft front and Super Soft rear, blinky 17.5 so they last decently.
toe 0*
camber -1*
#6612
front
toe 0*
camber -1*
toe 0*
camber -1*
#6613
Just finished putting together my SCT. Do you have to solder your motor up with the motor out? There's a lot of plastic in my way!
#6615
the truck mainly pushed on an off camber corner and a drop off then turn left to the line, that was it.
but i think that was mainly due to tire choice (enduros) I think I will run the Blockades, I think they were better for this track.
rear traction is good, I have tried soft and super soft, both work really well. only when its a loose top layer (practicing, or on race days nobody wants to sweep the track
