TLR 22SCT Thread (Check First Page for FAQ & INFO)
#6451
To use the vts slipper, u will not be using the TLR spring and red washer, they will be replace by the ones provided with the AE diff rebuild kit. The part number is on the front page and i'm on my iphone so its a pain to go back and forth to look it up right now but the ae diff rebuid kit as well as the vts slipper kit part numbers are there. Also you'll need an AE spur gear. If u need up close pix, let me know, I'm happy to take them when I get home if you'd like.
#6452
I just got a 22sct and the sway bar kit...i have no friggin idea how to install the rear sway bar...can someone give me an idea...i see where the front go but the back...no idea.
Anthony
Anthony
#6454
It came with instructions guys!
Scott you have the mounts to the ESC try on back wards. They are supposed to support the bar away from the rear tower. This allows the vertical standoffs to remain verticle.
Update:
This is why you have your upper inserts in the uprights backwards.
See Grandturk's dirty truck photos below!
Update:
#6455
Thanks for the pic...but I can't see it very good...any other help is much appreciated...
#6456
#6457
#6458
I have the stock seventy something spur...what is a good gearing for this truck on a indoor clay track...decent size tracks with 2 doubles and a crossover.
Anthony
Anthony
#6459
I've been using the Triad clutches in all of my TLR rides. I prefer it over the stock(not that it's bad, because it isn't) as I've found it to be more consistent once it gets warmed up. 2wd SC weigh more than the average 2wd ST or buggy. I set mine up so the front end unweights but doesn't lift the tires off the bench. I was also recently sent the new "red" Triad pads and am due to test them on the track later this week. They offer more "bite" and should be great for 2wd SC.
#6463
Update:
Update:
Anyone see this new MIP "Super Diff" for the 22 series cars? Nice to have another aftermarket option. If anyone tries it out, please post with their thoughts.
http://www.liverc.com/news/new_produ..._Diff_Kits%22/
#6465
