TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 02-25-2013, 01:50 PM
  #6241
Casper, I dont know if you saw my post earlier. I put your latest set on my truck last week. It handles great. I even won the SC class for the first time. But the question i have is, when the front shocks are fully extended, there is a gap between the spring adjuster and the spring. Is that the way it is supposed to be?
Dale.0 is offline
Old 02-25-2013, 02:01 PM
  #6242
Originally Posted by xlayedoutx View Post
Almost have my truck where I want it. Had a huge problem with the rear kicking out after about 8-9 packs and could not get it corrected. I went against what I know and made a lot of changes at once. In part because I was so frustrated. As I said in another post I was finishing 1st and 2nd up until I had the rear start kicking out. Anyways I moved the rear hubs all the way forward, I switched out to a gear diff, and turned my throttle expo up. All that was a night and day difference as I finished 1st, 2nd, then a bad tire change put me in 4th in the main. Not sure what else is left to adjust except tires but I'm almost there.
Maybe your front end is too well planted, that will cause hooking.
You could try one or more of the following to make the front end push more:
Heavier front springs, thicker front shock oil, front sway bar and no rear bar, reduce your steering travel limit, move the battery back.
gmackhurry is offline
  #6243
Casper's Avatar
Trader Rating: 34 (100%+)
Sorry I missed that. Mine are the same way and this is ok. We ran a similar situation with "buggy" front springs on the XXX-T and XXX-SCT.
Glad you are having success with the setup!
Casper is offline
Old 02-25-2013, 02:08 PM
  #6244
Casper, Cool, just wanted to check.
Dale.0 is offline
Old 02-25-2013, 02:46 PM
  #6245
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Would more toe in also help in more forward bite on the straight? I have the stock 3deg... maybe a 3.5? not sure what i would loose by adding more toe in.
mysupratoy94 is offline
Old 02-25-2013, 02:53 PM
  #6246
R/C Tech Elite Member
LBR_Frank's Avatar
My understanding is adding more toe slows you down a bit by adding more resistance/traction, this is really only an issue in Stock racing. Mod guys I know tend to run 4* including myself because there is enough power there that the extra resistance won't matter vs the gained traction. example on my stock 22 buggy I run 3* and am considering going down to 2*.
LBR_Frank is offline
Old 02-25-2013, 02:57 PM
  #6247
Hey guys,
Built my shocks on the 22sct. The question I have is why do the shock springs rub against the shock bodies. I moved them around turned them upside down to try and find a smooth spot and normally I can but with these springs I couldn't. Is that fairly normal and does the spring hitting the shock body hamper dampining? Thanks.
Whitey_Wangster is offline
Old 02-25-2013, 03:03 PM
  #6248
Casper's Avatar
Originally Posted by Whitey_Wangster View Post
Hey guys,
The springs are not going to be perfectly flat on both ends so a slight rub is pretty normal.
Casper is offline
Old 02-25-2013, 03:18 PM
  #6249
Thanks Casper,
One more question on wheel hexes. If I go with the 1.5mm 22 frt hexes and the 1.5mm 22sct rear hexes will this help with traction on loose bumpy tracks and is it still ROAR legal? Thanks
Old 02-25-2013, 03:20 PM
  #6250
Casper's Avatar
Thanks Casper,
Front yes legal. Should be slightly more stable.
Rears assuming you are not running a lot of toe it will be legal. Wider rear end should have some more forward bite narrower rear more side bite.
Casper is offline
  #6251
ok, maybe ill try going to a 3.5 if all else doesnt work.
Old 02-25-2013, 03:53 PM
  #6252
Jokermayhem's Avatar
Default anybody going to the 2013 Short Course Showdown Nationwide Tour ??
I'm going to the one in Massachusetts March 22-24th. It would be fun to meet some of you on here if you're going.
Jokermayhem is offline
Old 02-25-2013, 04:34 PM
  #6253
ScottKelly911's Avatar
Originally Posted by acuratech View Post
hmm the hole in the spindle is small for the stock king pin.
in order for me to use these it looks like it needs to be drilled ?
If it's too fat for the holes, check your packaging to make sure you didnt accidentally buy the threaded hingepins. You need the threaded Kingpins check front page post for the correct part numbers.
ScottKelly911 is offline
Old 02-25-2013, 05:09 PM
  #6254
Grandturk's Avatar
Planning on it.
Grandturk is offline
Old 02-25-2013, 05:52 PM
  #6255
Sweet Grandturk...it'll be sweet to meet some people from this forum...The real name is Dan Dugan by the way...
