TLR 22SCT Thread (Check First Page for FAQ & INFO)
#6196
Sapperc and I race the same track. It is very bumpy and slick. Its a place wear the person with the correct set up run up front. We have a 10 year old kid dominating every race day withe a lcg slash and a box stock 4x4 slash with a good set up. That's what's been so fun with this 22 platform. Going from an sc10 that was dialed to floundering with my 22. After tweaking and testing the truck is performing just like it should. Box set up is a good starting point but you can get more out of the truck by tweaking and testing. I'm running a very similar set up as gmackhurry. It can be found on the first page under member setups. I did change shock setup to, front: 55 piston 30# oil no limiters green spring and 3 turns out on the eyelet. Rear: 54 piston 25# oil no limiters white spring and 1.5 turns out on the eyelets.
I'm very happy how the truck handles the roughness of our track. I'm also getting great forward and side bite. The stock shock settings were just way to rigid for me. I also don't see the benefit of going to a two hole piston in this application. Way to much pack.
#6197
#6198
I am picking up a diff rebuild kit and it is cheaper to buy the out drives seperately, so I guess my question is, does any one run the light weight out drives? I am going to be running a 13.5, would these hold up or should I just pick up another set stock ones instead? I bought the truck used and I have no idea of the wear that has incurred. Thanks for the help in advance.
#6199
Hey guys I'm thinking about trying out the ae 2 hole pistons. What would you guys suggest for hole number and weight oil. I am running on a high bite carpet track. Thanks for any input.
#6201
I see why you'd get the service kit ($25) over the complete kit ($50) since the outdrives are $18
BUT! the complete kit comes with the outdrives ($18) AND 5x8mm ball bearings! which on are 8 dollars!
so it is $50.99 on amain for the complete kit,
then $24.99 for the service kit + outdrives at $17.99 + 5x8x2.5mm ball bearings at $7.29 = $50.27
I would think get the complete kit, so you don't have worry about buying bearings. then, you can maybe service the other one and have a spare on hand.
Remember to use the Associated Diff Screw!!!
#6202
I have to agree this is a fun truck to work on, it so adjustable and responds so well to minor changes. No need to get really extreme with rear toe, anti-squat, etc.
#6203
#6204
Casper or Ryan, I put your latest set up on my truck. Two things seem funny I just wonder if I did somthing wrong. When the front shocks are extended the spring is loose up and down. If I tighten the collor to touch the spring the ride hight is too high. Also it seems to have a lot of bump out. It looks like I have done everything right but maybe not.
#6205
saving up for a bfast kit for my 22sct and my 22t. I need to pick up a 13.5 or a 10.5 for the 22t before I put any ball diff in it. it has a gear diff in it currently, to take the massive and stupid power of the traxxas VXL it has currently.
#6206
#6208
Suspended
Like most rc suspension pieces, sway bars need to have 'some' play built into them or they will bond up the suspension and ruin the handling of your car/truck.
#6209
Not sure what you mean, because the only way the rear (center) mounts will secure the swaybar is with the channel facing down.
#6210
I know this sounds stupid and you probably didn't do this, but my friend did this with his 22 Buggy, so it's possible you might have made the same mistake. He put the front Caster blocks on the wrong sides and had MASS bump out when he would compress the shocks. everything looked right and we couldn't figure it out until we put our cars right next to each other and started going over every single component piece by piece and that's when we noticed he had them on the wrong sides. Worth a look anyway.
