TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 02-20-2013, 02:45 PM
  #6136
Carranza76's Avatar
Originally Posted by kjohnsiii View Post
I like that idea, any other scb conversion options out there?
this: http://www.amainhobbies.com/product_...sis-Dirt-Cover
Carranza76 is offline
Old 02-20-2013, 05:25 PM
  #6137
Guch's Avatar
Default New Steering for the 22 platform
I may be a dollar short and a day late but has anyone seen this new steering, for the 22 platform, someone has been working on?
http://www.rcdriver.com/rcd/index.ph...ck-for-the-22/
Guch is offline
Old 02-20-2013, 05:37 PM
  #6138
Jokermayhem's Avatar
This may be a dumb question...but here it goes anyhow... I just purchased the thicker(wider) 1.5mm hex for the rear of my 22 SCT. Since this maxes out the rear do I put wider hexes on the front as well??? Note: I am using the stock 22 SCT rims with stock offset...thanks
Jokermayhem is offline
Old 02-20-2013, 05:48 PM
  #6139
Casper's Avatar
Trader Rating: 34 (100%+)
The front is pretty much max width alreadys. You can put the buggy +1.5 hexs on the front to get a little more width but it is not much.
Casper is offline
Old 02-20-2013, 05:50 PM
  #6140
ok cool....thanks Casper
Old 02-20-2013, 07:58 PM
  #6141
AndrewTom's Avatar
I saw that coming!!!
when I build my 22sct, I noticed they put in those two aluminum ?sleeves? with the plastic spacers. I looked at it, and was curious how long it would be.
AndrewTom is offline
Old 02-20-2013, 09:25 PM
  #6142
Adonis_mp's Avatar
Trader Rating: 8 (90%+)
Originally Posted by ScottKelly911 View Post
I ran it for a very short time and was not impressed. Now I run the Associated VTS slipper for the SC10 4x4. MUCH more pad surface area. I just had to replace my pads this past Sunday, I've been running the same pads since about a week after I built the truck (I got the truck the first week it came out). After about a week on the Avid and not being able to really get it where I wanted it, I took it out and put in the AE VTS and been really happy with it ever since. Do note that if you go to the VTS slipper, you will have to either mod your gear cover or use spacers to push it out further. I just used washers because I run indoors and dont need the protection from the elements so there's some space. But if you run outdoors or on real dirt, you'll probably want to use some type of rubber as a seal/spacer. I have the VTS mod on page 1
Would you say that it is better than stock? I don't want to modify the cover so I'm looking for something better than stock.
Adonis_mp is offline
Old 02-21-2013, 12:01 AM
  #6143
ScottKelly911's Avatar
That looks very interesting! hard to really see much from the pic, but it looks like they made bellcranks and used a piece of Carbon fiber to connect the two bellcranks together as well as mount the ball studs to. Very interested in seeing how it works in person.
This is a sticky question my personal answer would be yes. But let me add the caveat, I'm not a great diff/slipper builder/setter. Infact i'm pretty bad at it but I'm getting better. I know of many people who've used the stock slipper with no problems, so some will probably say no need. But for me personally, I've glazed several stock pads in my RCRD 22T to 22SCT conversion (before the real thing came out) a ton of times and could never really get it to set correctly with the 6.5T motor I was running. Eventually went to the Avid slipper. So once I bought my REAL TLR 22sct, I never even installed the stock one and went straight to the Avid. A week later, I went to the Associated VTS slipper and feel it is the easiest to set up, due to all the surface area I feel it grabs really well and you don't have to crank it down super hard like you do the stock ones and as an added bonus, the pads fit into a clutch-basket, so changing the pads is the easiest I've ever done, you don't have to hold them into a groove or notches and hope they don't slip out as you slide the entire spur gear up the shaft lol it's honestly one of the best mods I've done in my opinion and super easy for maintenance as well. What I'd suggest about modding the cover is to maybe get some closed cell foam and make a gasket around the edge to use as a spacer so you don't have to cut the cover at all, kinda like this pic below.
ScottKelly911 is offline
Old 02-21-2013, 06:52 AM
  #6144
weavty1's Avatar
^WOW, now that is a huge damn picture... Can't even understand the context of what the hell that even is...?
weavty1 is offline
Old 02-21-2013, 07:51 AM
  #6145
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
At least Scott keeps his finger nails clean..
kjohnsiii is offline
Old 02-21-2013, 09:35 AM
  #6146
Carranza76's Avatar
Go to the 22 Buggy thread it is being tested out right now by a company called Akula Racing in the UK.
Check their site they make a cool looking CF chassis for the buggy/
I had heard that TLR was working on something like this but do not know it to be true just talk. I know non of the TLR guys here would be able to comment if they were.
Old 02-21-2013, 10:12 AM
  #6147
Trader Rating: 83 (100%+)
Can you guys post up your gearing for running with a 13.5T motor?
bigbeej is offline
Old 02-21-2013, 10:14 AM
  #6148
AndrewTom's Avatar
what motor? boosted or blinky?
I am at 26/78 blinky 17.5. viper vst 17.5 @35* static. i am going to try moving up to 40* next time I am at the track.
Old 02-21-2013, 10:16 AM
  #6149
gawith0413's Avatar
Trader Rating: 86 (100%+)
First page. 78/21
gawith0413 is offline
Old 02-21-2013, 10:28 AM
  #6150
Thanks I am running the 78/21 now but feel like I can step it up some. I am running the D3 13.5 with endbell up halfway. Another issue I have is I have the avid slipper but only have 75T, 81T, 84T spurs right now and was looking to use them so I don't have to wait for another order.
bigbeej is offline
