TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 02-17-2013, 07:42 AM
  #6076
Rogue_Texan's Avatar
Trader Rating: 15 (100%+)
Originally Posted by drepus View Post
Firewood is right it comes in the steering rack bag. TLR1056 is the part number and you'll end up with a spare rack for when you need it.
Well that makes sense then. I thought he meant in the kit not as in replacement parts, I had been looking for just the shims this helps a lot thank you guys.
Rogue_Texan is offline
Old 02-18-2013, 05:09 AM
  #6077
spider882009's Avatar
Trader Rating: 7 (89%+)
Well back to Club Racing with my 22SCT in the 17.5 2WD Short Course Class @ PT-Raceway!!! I can't wait for summer and get out doors!!!
Has anyone used the JConcepts Wheel Caps for the 22SCT??? And do the come in any other color???
spider882009 is offline
Old 02-18-2013, 07:47 AM
  #6078
Just finished my 22SCT Sunday and took it to Pegasus Hobbies to testdrive. It was my first time back in the hobby for 15 years and the car worked fantastic. Took some bumps that would have destroyed my XXT back in the day but I can report no broken parts and it handled great. My setup was totally stock out of the box except for the TiNi kingpins,AE pistons and diff parts. I've decided to wait to tinker with setups until after I get a few weeks of laps under my belt. As is, it felt awesome. Great work TLR!
johnmo is offline
Old 02-18-2013, 08:09 AM
  #6079
First time running the casper/dunford set up on a very high bite clay track(leisure hours in joilet Ill) I put on black fr springs and ran a pink sway bar up front the truck was pretty good my boy was'nt use to running a track with that much grip. Any advice on taking away some front grip on a very high bite track. There was a high speed sweeper he had problems with I realize he needs to adjust his approach on a track like that but maybe there is more I can do in the set up.
tekinACE is offline
Old 02-18-2013, 08:21 AM
  #6080
weavty1's Avatar
What tires were being used?
weavty1 is offline
Old 02-18-2013, 08:25 AM
  #6081
Early I was running slicks in the rear a rattlers up front as the track dried out bar code all four
tekinACE is offline
Old 02-18-2013, 08:28 AM
  #6082
weavty1's Avatar
What compound barcodes?
weavty1 is offline
Old 02-18-2013, 08:32 AM
  #6083
weavty1's Avatar
Just asking, because if it was TOO hooked, you can always go up in tire compound (harder), to get it situated a little more loosely, since you were having too high of traction in some areas.
weavty1 is offline
Old 02-18-2013, 09:14 AM
  #6084
Casper's Avatar
Trader Rating: 34 (100%+)
For really high bite I would take some of the droop back out of the car. This setup is more for med to lower traction with all the droop. As traction goes up to high bite less droop especially in the front would be a good change but it is simple to test as you just adjust the shock end and see how you like it.
Casper is offline
Old 02-18-2013, 10:58 AM
  #6085
Thanks weavty and casper next time i'll try that. Not use to running on a track with to much grip. He did make the a main in mod sc but stock sc was a hack fest and he got frustrated and was over driving and had issues with traction rolling. Thanks again
tekinACE is offline
Old 02-18-2013, 01:54 PM
  #6086
Rusty Old Fart's Avatar
Trader Rating: 21 (100%+)
I suppose this has been asked a thousand times but I had a search and could see a list or answer. Is the a list of conversion parts from 22T to the 22SCT. From the exploded diagrams it appears to only be a handfull of parts and a shell. My reason for asking is I have a 22T sitting there and my would like to run SCT but its the expense of another complete truck. So if its only a few parts he could do it just to get a taste of running SCT.
Rusty Old Fart is offline
Old 02-18-2013, 02:00 PM
  #6087
Grandturk's Avatar
It's the entire truck minus the transmission and shock towers and steering rack.
Grandturk is offline
Old 02-18-2013, 02:45 PM
  #6088
I read earlier that it used the same arms as the truck and many other pieces were the same. hhmmmm must have it wrong then
Old 02-18-2013, 03:09 PM
  #6089
Grandturk's Avatar
Nope arms are different. One team diver has been using rear 22T arms but thats not the norm.
Old 02-18-2013, 03:17 PM
  #6090
My suggestion then is (Keep saving boy)
