TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 02-11-2013, 12:56 PM
  #5941
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Adonis_mp View Post
I'm using the Dunford/Casper set as a base line but I'm looking for a set up better suited for my local track which is a large 1/8 scale. Big jumps, med bite, bumpy and fun. The fast guys are running it at about 32 sec.
Is the truck not doing something you would like? I can't read much into your statment other then you want a whole new setup? 32 second laps sounds like a pretty big track is all I was able read into that.
Casper is offline
Old 02-11-2013, 12:57 PM
  #5942
Originally Posted by Casper View Post
You have to just run a looser slipper. The slipper must always give before the diff or the diff will be toast in no time. I have to ask. You are using clear grease on the main balls and black grease on the thrust. Also on the main balls you don't need a LOT of clear grease. Just a bead on each ball is sufficient.
Black grease on the thrust and just a small film of clear on the main balls. Black grease behind diff rings. I will try tuning the slipper a little better for a better balance.
slodustin is offline
Old 02-11-2013, 01:00 PM
  #5943
ScottKelly911's Avatar
Originally Posted by acuratech View Post
Scott
where did you get the blue hardware, also have you had any issue with the link hardware snapping since it's aluminum ?
Hey Acuratech, all the blue anadized hardware on my car is made by Ofna. I got most of it from amain hobbies and Nitrohouse. My Blue turnbuckles are trxxas captured ends. Let me know if u have any other questions. Hope that helps
ScottKelly911 is offline
Old 02-11-2013, 01:12 PM
  #5944
will g's Avatar
Trader Rating: 132 (100%+)
What set up should i look at for med size track with alot of loomy dirt .. low-med bite and will be very bumpy/ruted up .. thanks in advance
will g is offline
Old 02-11-2013, 01:15 PM
  #5945
Grandturk's Avatar
I'm not going to say not to do it because I've never tried it, but I've never heard of black grease being used behind the diff rings. I've always seen instructions to build with silicon behind the diff rings. You may want to rebuild your diff.
Grandturk is offline
Old 02-11-2013, 01:16 PM
  #5946
drepus's Avatar
edit:gradturk, you beat me to it...8)
Why black grease behind the rings? If it was to work its way onto the main diff balls the diff would not feel good at all! I would suggest clear behind the rings as maybe it is the black grease that is helping the diff rings slip against the outdrives.
drepus is offline
Old 02-11-2013, 01:45 PM
  #5947
Adonis_mp's Avatar
Trader Rating: 8 (90%+)
I haven't used your complete setup yet, still waiting on some parts, but I believe your setup was for a regular indoor manicured track. I was looking for possible changes that someone has made to accommodate the larger size of the jumps and track.
Adonis_mp is offline
Old 02-11-2013, 04:48 PM
  #5948
I would start with Frank Roots Short Course Showdown from Mikes hobby shop, 2012. The track was low to medium bite, blown out and inconsistant. It is a very forgiving set up that hooks up great on low bite conditions.
losi b is offline
Old 02-11-2013, 06:45 PM
  #5949
Casper's Avatar
Black grease is a bad idea behind the main ring. Silicone is the only thing to use for the main gears as there has to be a level of friction required for those to drive. If you have a grease that reduces friction too much the drive rings will slip and you can't get the diff to set. ONLY clear grease around the main balls and rings. The thrust bearing you can use black grease or other similar hi pressure grease.
Ryan and I find setups we develop at OCRC to translate well to other track conditions with the use of appropriate tires. Not saying it is going to be perfect for you and your track but give it a full try. The Root Mikes hobby setups is popular with guys that are running low traction as well so that might work well for you as well.
Casper is offline
Old 02-11-2013, 06:57 PM
  #5950
Adonis_mp's Avatar
[QUOTE=Ryan and I find setups we develop at OCRC to translate well to other track conditions with the use of appropriate tires. Not saying it is going to be perfect for you and your track but give it a full try. The Root Mikes hobby setups is popular with guys that are running low traction as well so that might work well for you as well.[/QUOTE]
Once again you guys have been a lot of help. I'm given your set up a try, thanks.
Old 02-11-2013, 07:06 PM
  #5951
Casper's Avatar
If you give me details of handling issues for your track and can help you tweak the setup for you as well so let me know.
Casper is offline
Old 02-11-2013, 07:11 PM
  #5952
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Casper I been having good luck with the Casper/Dunford setup in 17.5 blinky with a shorty (4 foams behind it) 2.5 rear toe block, no added brass weights. I just need to fix one thing the inside rear tire wants to spin to much on corner exit, I tightened the diff to the point where I'm nervous about snapping the diff bolt. Any ideas on how to keep that inside rear tire from unloading? (I think unloading is the correct term for this???)
Gas Rat Racin is offline
Old 02-11-2013, 08:01 PM
  #5953
gawith0413's Avatar
Trader Rating: 86 (100%+)
Hey Casper,
Do you guys set toe? If so, how?
gawith0413 is offline
Old 02-11-2013, 09:30 PM
  #5954
Casper's Avatar
Humm. I would do two things. I would move the battery back two pads just to see how more weight back effects this. Then I would pop off the swaybar to see if that helps as well.
Casper is offline
Old 02-11-2013, 09:51 PM
  #5955
Casper's Avatar
Originally Posted by gawith0413 View Post
Hey Casper,
Set it buy eye. Start with the links the same length and always make equal adjustments.
Casper is offline
