TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 02-07-2013, 07:05 AM
  #5851
gawith0413's Avatar
Trader Rating: 86 (100%+)
Casper,
You run Tekin RS pro, if you don't mind me asking. How you have your esc setup. Thanks
gawith0413 is offline
Old 02-07-2013, 08:25 AM
  #5852
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by gawith0413
Casper,
I setup all my ESC's pretty much the same. Here is a setup from my 22 10.5 I am running a 8.5 in my SCT right now with no boost.
http://www.teamtekin.com/hotwire/ESC..._10.5_v212.pdf
Casper is offline
Old 02-07-2013, 08:26 AM
  #5853
Originally Posted by Casper
35 is a lot of drag brake. Turn it down to the 10-12 range.
Will do!
thanks again
RcNuttz is offline
Old 02-07-2013, 08:37 AM
  #5854
gawith0413's Avatar
Thanks!
Old 02-07-2013, 10:56 AM
  #5855
Grandturk's Avatar
Aluminum driveshafts just announced. Wonder how they will hold up. Good for stock racing - but I can't imagine you'll get many runs out of them in Mod.
Grandturk is offline
Old 02-07-2013, 11:03 AM
  #5856
spider882009's Avatar
Trader Rating: 7 (89%+)
Default When???
Are they TLR parts??? Why wouldn't they last for Mod???
spider882009 is offline
Old 02-07-2013, 11:12 AM
  #5857
Grandturk's Avatar
Yes TLR aluminum driveshafts. Tlr332004
I would imagine they will get chewed up pretty quickly but may be a "speed secret" for an extra $20 every weekend.
Old 02-07-2013, 12:02 PM
  #5858
Casper's Avatar
The should last a while especially in stock. I ran alum universals on my XXX SCT for a long time in mod. Held up great but not quite the same as how an alum CV joint works. They have a steel cross pin still so the only wear side would be the CV joint. Again my experience with alum bones is they should do just fine.
Casper is offline
Old 02-07-2013, 12:10 PM
  #5859
Grandturk's Avatar
Oh it does have a steel cross pin - that's good. I was imagining it with aluminum cross pins. That would be pretty soft against the steel outdrives. Good stuff. Already asked my LHS to get these for me!
Old 02-07-2013, 12:40 PM
  #5860
ok guys i put my truck together last night. well about 90% of it. One thing i noticed that i did not like was the steering rack seemed to be kinda hard to move back and forth. I know people said they break easy so might as well upgrade it right away. well i figured its brand new so might as well break it first. Anyways is there a way to adjust it to make it turn smoother and easier?
bbischer1 is offline
Old 02-07-2013, 12:46 PM
  #5861
Casper's Avatar
I don't think most poeple complain it breaks easy but does "wear in" quickly and gets more sloppy then some people like. As long as it move without a "catch" I would just run it and it will seat in pretty quick.
Casper is offline
Old 02-07-2013, 12:59 PM
  #5862
ok thanks. I was really happy with the quality of most of it but thats one thing that scared me a little. But i figured it just needed a break in period. Also one other question. i need a good starting point for a 7.5t orion ran with a tekin rs esc. I ran a 8.5t in my sc10 and liked that but decided to step it up a notch. Spur/pinion and also esc set up would be helpful.
Old 02-07-2013, 01:05 PM
  #5863
Casper's Avatar
Due to tranny differences I would drop 2 teeth from what you ran on your SC10 and try that with your 7.5 in the 22-SCT.
ESC.
Throttle profile 3 (linear)
CL 80%
Drag brake 12
Neutral width 10
Min brake 12
No timing
Brake 100% (adjust radio for final setting)
Throttle 100%
I think that covers the highlights.
Casper is offline
Old 02-07-2013, 04:51 PM
  #5864
Butch Mann's Avatar
Trader Rating: 40 (100%+)
Tip someone gave me on here for the rack. Take a #2 pencil and run it over the slider part of the rack it will work super smooth. Try it you'll like it!
Butch Mann is offline
Old 02-07-2013, 07:11 PM
  #5865
Thanks!
Pay attention to the version 212.Make sure your on the same version with those settings and not the newest 223.
Losi57 is offline
