TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 02-01-2013, 10:20 AM
  #5686
Grandturk's Avatar
Originally Posted by LBR_Frank View Post
Good to know what kind of mileage to expect. it's only got about 3 race nights on it, but that's about 20 heats. Plus some practice hours. Seems soon, but could be cooked I guess.
I'm still running my original rack from August. I think it gets better with a little more slop and doesn't bind.
Grandturk is offline
Old 02-01-2013, 10:50 AM
  #5687
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by gawith0413 View Post
Well I'm going to be running a 8.5t, and my SMC's are about 299g, so I should be good. Also I know this has probably already been discussed, but what are the TLR tranny weights you and Ryan are talking about on your collaborative set-up?
http://www.tlracing.com/Products/Def...ProdID=TLR4167
Casper is offline
Old 02-01-2013, 10:52 AM
  #5688
gawith0413's Avatar
Trader Rating: 86 (100%+)
Yeah, I saw that after I asked the question. So I would use both 7g weights?
gawith0413 is offline
Old 02-01-2013, 10:56 AM
  #5689
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Does 7+7 equal 14?
Gas Rat Racin is offline
Old 02-01-2013, 11:00 AM
  #5690
It's a truck to truck basis.i had one rack that would catch on me at random times but it was only when I turned right and while the suspension was compressed.I went through my whole truck replaced everything but the rack because it was free Everytime I checked it.my buddies was doing the same thing and when he replaced the rack it stopped.After about two weeks if it driving me crazy I finally said fine ill replace the rack.Problem solved.Niw I just saved self the aggravation and replace it before it gets too sloppy
Losi57 is offline
Old 02-01-2013, 11:03 AM
  #5691
R/C Tech Elite Member
LBR_Frank's Avatar
Originally Posted by Gas Rat Racin View Post
Does 7+7 equal 14?
Sometimes I wish there was "like" button, or a "+1"
LBR_Frank is offline
Old 02-01-2013, 11:05 AM
  #5692
LBR_Frank's Avatar
Probably the best point of all. sometimes it is, what it is.
Old 02-01-2013, 11:06 AM
  #5693
gawith0413's Avatar
Does 7+7 equal 14?
Let me use my calculator!
Old 02-01-2013, 11:07 AM
  #5694
Casper, Do you have a suggestions for gearing for 13.5 blinky?
Dale.0 is offline
Old 02-01-2013, 11:23 AM
  #5695
Casper's Avatar
This depends on motor and endbell timing but using an educated guess I would start in the 23-24/76 range and adjust from there.
Casper is offline
Old 02-01-2013, 12:09 PM
  #5696
Casper, My son and I have two 22sct's there both setup with tekin RS ESC's driving Ballistic 17.5t motors we are just getting in to racing (blinky) the track is indoor clay medium/high traction what would be a good starting point for gearing?
RcNuttz is offline
Old 02-01-2013, 12:13 PM
  #5697
Casper's Avatar
Novak Ballistic motors tend to run a little on the hot side. I would start 25/76 and go up from there temp permitting. You want to keep the motors under the 160-180F range if possible.
Casper is offline
Old 02-01-2013, 12:32 PM
  #5698
thanks
is there a motor you would recommend for the 17.5 class that would be a good match the the tekin rs's?
RcNuttz is offline
Old 02-01-2013, 12:35 PM
  #5699
Casper's Avatar
thanks
Tekin Redline G2.
http://www.teamtekin.com/redline_gen2.html
Casper is offline
Old 02-01-2013, 12:58 PM
  #5700
hweaver184's Avatar
Trader Rating: 15 (100%+)
i tried out the setup with the droop that casper mentioned with no limiters and turning out the eyelets. Thanks casper, i can now take the sweaper at the local track at almost twice the speed and the truck handles like its on rails now. Very forgiving on the whoop section and doesnt have any on power spin outs now. I didnt realize how much droop on a 2wd truck mattered until i did what you said. "the fast guy" was there today at the track during lunch break when i went and i was staying with him the whole time. More than pleased with the truck. Best money ever spent IMO for a short course. Great job Losi on this truck. By the way, he was running an sc10.
hweaver184 is offline
