TLR 22SCT Thread (Check First Page for FAQ & INFO)
#5680
I gave it a shot and it would bind on me at random times so I went back to plastic.In my opinion the rack should be changed every three months depending on how much you race.Its Definately not the best steering rack I've seen
#5681
I run the Orion Carbon Pro 90C 5000mAh pack, which weighs about 275g. In the 22SCT, people have been adding even more weight (I don't) so a 300g+ pack may not be too bad. One this to keep in mind though, you can always add weight to the your car with lead or steel, but it you won't be able to take weight out if you get a heavier battery.
#5682
Frank or Casper, What gearing would you use for a 13.5 blinky?
#5683
#5685
Ryan and I have been running Venom 5000 60C which are about 294g. For stock I would get a light pack (short to really save some weight) but mod I would not be too worried about battery weight personally. 10-15g on totally battery is not going to have a huge effect in for as large as the battery is. (basically not a concentrated wieght over an axle.
